1973 Big Block-Electrical
Old Jun 29, 2009 | 08:47 PM
axle83651's Avatar
axle83651
Navigator
Default 1973 Big Block-Electrical
My 73 Big block will not turn over when the engine gets warm. The starter is brand new and is working properly. A jumper wire placed from starter to the battery will cause the engine to roll and start just fine (if the key is turned on). Using the ignition key, the engine will not roll. Allowing the engine to cool for a couple hours will allow the engine to be started using the key. Any ideas on the where the problem might be?
Old Jun 29, 2009 | 11:25 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Sounds like some heat soak in the starter. The original starter had a tin heat shield between the exhaust manifolds and starter.
Odd though, that it turns over with a hot wire. With the hot wire does the motor spin freely when hot?
You might test voltage to the starter solenoid.
Lastly, I use the high-torque mini-starters. Being smaller, there's more air cushion between the starter and exhaust manifolds; less chance for heat soak.
Good luck!
Old Jun 29, 2009 | 11:43 PM
Iliad's Avatar
Iliad
Some things to check are neutral safety switch, key switch, starter solenoid and battery. Do you have a wiring diagram to isolate the problem? If not, you can get one here; http://www.nrjvette.com/johdotukset/?c=d;o=d
Old Jun 30, 2009 | 08:12 AM
jnb5101's Avatar
jnb5101
if the hot engine cranks when you jump a wire directly from the battery, i would clean and tighten the connections at the starter and battery.
Old Jun 30, 2009 | 08:49 AM
...Roger...'s Avatar
...Roger...
But a solenoid that is border line and is effected by heat soak will sometimes engage with a more direct jumper especially crossing the S terminal with the pos post on the solenoid.
(This borderline solenoid usually will only get worse to the point of the more direct jumper will not work anymore.)
To 1973 Big Block-Electrical
