what intake will fit?
Jun 30, 2009 | 03:53 PM
I have a 81 with a 500hp small block , I want to remove the edelbrock proflo injector system in favor of a carb. everywhere i look it states will not fit under a corvette hood? What will fit under a stock 81 hood?
regards
Tim
tmcpherson@cogeco.ca
Jun 30, 2009 | 04:36 PM
In your hp range a Victor Jr with a drop base air cleaner would be your best bet.
Jun 30, 2009 | 04:41 PM
Quote:
Originally Posted by
tttims 81
, I want to remove the edelbrock proflo injector system in favor of a carb. [/email]
Why are you going backwards. The EFI system will run much better if it is setup and tuned correctly.
What is your motor setup right now?
Jun 30, 2009 | 04:46 PM
re efi
Gordonm
I cannot get it dialed in I believe there is a problem with it losing the settings everyother day and I cannot aford the 1900.00 upgrade to pro flo 2
Jun 30, 2009 | 04:47 PM
have you tried this? it will fit?
DRIVESHAFT
Jun 30, 2009 | 05:05 PM
I have not personally tried it.
Do a search on the forum for posts by 'Motorhead'.
He is running a Vic Jr and has posted many pics of it.
Jun 30, 2009 | 05:17 PM
Before FI I ran a Victor Jr on my motor. The early C3s had less hood clearance than the later ones so you should clear fine with a drop base air cleaner.
Jun 30, 2009 | 05:40 PM
I've run an RPM, and Vic Jr with drop base air filters, and though it took a bit of tweaking, managed a nice billet oval on the RPM I'm running now.
Jul 1, 2009 | 08:06 AM
The Money Pit
Thank you very much for the help , it saved me some wasted money
Best regards
Tim
Belleville Ontario
Jul 1, 2009 | 08:07 AM
The Money Pit
by the way which was the better manifold for you?
