carb tuning
Old Jul 3, 2009 | 03:02 PM
TyCor's Avatar
TyCor
Default carb tuning
I have been searching the forum for some guidance on how to tune my Q-Jet, after that I am going to attempt to set the timing. I just got my carb back from carburetorUSA, in NJ, it is now running rich, so I need to adjust it, but don't want to screw it up--at least it will start?? any help woud be great. 1977, auto, TH350, the carb I belive is off of an '84 truck...the jets may be a little bigger than stock. thanks.
Old Jul 3, 2009 | 03:44 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Start car and warm fully.
hook up a vacuum gauge to manifold.
adjust idle to specs with idle screw.
Verify timing is correct.
adjusting mixture screws a little at a time trying too
turn each one equal amounts try to achieve the greatest
vacuum reading all the time readjusting idle screw to spec rpm.
then a stock setup would be, turn in both mixture screws a little
to get a 50 rpm drop.
this is known as the lean drop.
Old Jul 3, 2009 | 03:57 PM
smon's Avatar
smon
Get a hold of Lars tuning papers. He will have everything you need to know.
Old Jul 3, 2009 | 04:27 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
They switched carbs on you?
You want to re jet?
Old Jul 3, 2009 | 04:42 PM
7T1vette's Avatar
7T1vette
You paid for a rebuilt carb for your car and they didn't set it up for your engine? That can be a problem as there are several areas of concern when the carb is running 'rich': jets and/or rods and/or power piston, etc., etc.
Old Jul 3, 2009 | 04:53 PM
TyCor's Avatar
TyCor
your right...and now I am having somewhat of a hard time trying to find someone who can set it up for me in Fairfax, VA. Adjusting the idle mixture seems pretty easy...but it really blows smoke under higher acceleration...how do I adjust this?
Old Jul 3, 2009 | 05:01 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Can of worms.
What color smoke, black?
Are you running stock motor?
Can you get the carb place to give you specs on what they gave you and why?
Now a days there are systems using O2 sensors that will guide you.
Back in the day, I would go to the library and get all the jet and power valve and needle specs for a motor that was similar to the motor
I was building. I.E. LT1, L88, ect.
Old Jul 3, 2009 | 05:26 PM
TyCor's Avatar
TyCor
Yes the smoke is whitish colored. you can smell the gas. the jets maybe too big...is this something I can change easiley? Can I change them with the carb on the car, or do I have to remove it?
Old Jul 3, 2009 | 05:28 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
white? water
Rich = black smoke
Oil = blue smoke
water/coolant = white smoke
Could it be light blue?
Are you using/losing oil or water?
sorry guy, time to pull plugs, compression test and check
radiator for exhaust gases.
To carb tuning
