Replacing Fuel Lines
Old Jul 4, 2009 | 02:26 PM
gnkjoy's Avatar
gnkjoy
Default Replacing Fuel Lines
Is it possible to install new fuel feed and return lines on a 71 without removing the body? I know you'd have to cut and splice the lines in front of the rear frame kickup. I've got the complete rear suspension out so now is the oppertune time if it's possible.
Old Jul 4, 2009 | 02:41 PM
Alan 71's Avatar
Alan 71
Hi G,
You can do it without cutting the lines but it's a pretty intense job and takes a lot of bending and then straightening. I hear it often takes a good bit of beer also.
Getting the old mounting clips and bolts out and the new ones installed is quite a challenge in a couple of places.
Good Luck!
Regards,
Alan
Old Jul 4, 2009 | 03:06 PM
gnkjoy's Avatar
gnkjoy
Originally Posted by Alan 71
Hi G,
Good Luck!
Regards,
Alan
I assume you're talking about new pre-formed lines. The necessary bending can be done without kinking the lines? Would it be any easier to cut and splice the lines? This is a restored original car but I'm not that **** that I wouldn't splice.
Old Jul 4, 2009 | 10:22 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Try and avoid the splices, gas and fiberglass = big fire, and a very bad day.
69VETT
Old Jul 5, 2009 | 12:39 AM
7T1vette's Avatar
7T1vette
Good quality compression splices [or re-flared for AN union fittings] that are hard mounted to the frame rail should be fine. Don't know why you couldn't do it with some 'massaging' of the stock line and a good flaring tool.
Old Jul 5, 2009 | 08:42 AM
Duke94's Avatar
Duke94
Here's a link to a thread that has a lot of info about replacing the lines.
Gary
http://forums.corvetteforum.com/c3-t...tallation.html
Old Jul 5, 2009 | 12:26 PM
Alan 71's Avatar
Alan 71
Hi G,
I believe David Mayhew (a member of this Forum) replaced the supply line on his 71, LT-!, without a splice. (I THINK). Try a PM to him for some advice.
Since it's a restored car it would be nice to have the proper lines on it.
I'm posting a couple of pictures so you can see how they go up at the frame kick-up and back to the tank.
Good Luck!
Regards,
Alan
To Replacing Fuel Lines
