Leaking Caliper?
Old Jul 7, 2009 | 03:09 PM
autimous's Avatar
autimous
Default Leaking Caliper?
So I'll begin with the disclaimer that I noticed the same thing about a year ago when I changed the rear pads and decided to ignore the problem, and between then and now I didn't crash (well, not the corvette anyway.)
I noticed a severe lack of braking power on the weekend so decided to change my front pads having replaced the rears not that long ago. I noticed when I was trying to encourage the pads into the calipers that I could hear a squelch and some fluid squirting out. It was only when I was trying to push the pistons in, so although common sense (of which I seem to be lacking lately) tells me that it's time to immediately change all the calipers I wondered if anyone on here has experienced the same problem?
Is it indeed a time for change... and on a scale of 1 to 10, how far am i pushing my luck by driving?
Old Jul 7, 2009 | 03:31 PM
autimous's Avatar
autimous
I suppose what I should be asking is:
Is it possible that allowing the pistons to come out as far as they do when the pads are out can cause a leak that goes away when the pads are in place and the pistons are depressed back into their sleeves. I'm aware that there are two kinds (lip or o-ring) and I'm not sure which kind I have, or whether this would make a difference.
Thanks for anyone that answers yet another one of my silly questions!
Old Jul 7, 2009 | 03:46 PM
75BrownC3's Avatar
75BrownC3
Since you let the pistons come out as far as they did, it is possible that you have air in the calliper itself. Try bleeding the brakes and see if the petal feels more firm and also check for leaks when you are done. If there are no leaks, you are good to go. If there are leaks, I would suggest to replace them.
Old Jul 7, 2009 | 03:51 PM
autimous's Avatar
autimous
I bled the brakes and they appear to be working fine, and no noticable leaks so far.
Does that mean that the squirting was a result of my pad changing technique? Seems far fetched but if it's true it'll save me $400 and a day of trying to change the calipers in my parking space!!
Old Jul 7, 2009 | 04:27 PM
7t5's Avatar
7t5
St. Jude Donor '14
Default !
If you experienced a "severe lack of braking power" and noticed "fluid leaking out" the calipers, what the heck are you thinking. Get those puppies correctly diagnosed before you kill somebody! If you do kill somebody, I hope they track down this post and prosecute you for negligence. Sheesh.
Old Jul 7, 2009 | 08:02 PM
autimous's Avatar
autimous
A bit harsh
Allow me to try again:
This weekend, my brakes felt less dynamic than usual. Feeling familiar to what I've experienced before, and knowing that my front pads were about due to be changed, I changed them.
While pushing the pistons in, forcibly, a minor amount of fluid was expelled. This only happened when I was forcing the pistons back in (to make space for the new, thicker, pads).
This happened once before about a year ago and following that change (the rear pads) there was no leak.
Since I have found this forum to be a place of advice and information, I thought that on this occassion I would see if this is a common occurrence - given the age of our cars I suspect it is - and what my fellow C3 owners did when in this situation.
Thank you all for your advice, as always it is much appreciated (except the previous post, you can go and f$#4 yourself)
Old Jul 7, 2009 | 09:00 PM
Bob89c4's Avatar
Bob89c4
My 71's brakes always feel spongy no matter what I do. I have owned the car 12yrs. Re-built the fronts and backs once and then last fall when I was on a great little cruise lost all brakes do to a left front leak. It was not a sudden thing, I felt the pedal going further and further down... headed home as soon as I felt it....
I guess I could have called a tow truck but I made it home fine. No I don't have much e brake left. I replaced the front calipers with auto zones. They are lifetime. I use silicone brake fluid and I try to bleed the system at least once a year.
Are your calipers original? Brake fluid Dot 3 or silicone?
The brakes on C3's really suck. The C4's are not much better!!!
Old Jul 7, 2009 | 09:37 PM
Fuelie74's Avatar
Fuelie74
Yes it is possible to cause a leak by letting the pistons come all the way out. Same thing with the master cylinder when you push the pedal all the way to the floor when bleeding your brakes. If the bore is crusty in the area that isn't normally used and you push the seal over the crust it will tear the seal.
Just go get a new caliper and be back on your way.
Old Jul 7, 2009 | 09:54 PM
7t5's Avatar
7t5
St. Jude Donor '14
I noticed a severe lack of braking power.......although common sense (of which I seem to be lacking lately) tells me that it's time to immediately change all the calipers
Change the story all you want. You stated a "severe lack of braking power" and you are concerned about whether or not you should change calipers, and asking us to rate how much "luck" you have left. Real nice. Have a nice life.
Old Jul 7, 2009 | 09:59 PM
MN-Brent's Avatar
MN-Brent
Your seal is ageing and starting to take a set to the outer ID area of the bore. Its possible the more internal ID area of the bore has a slightly different dimension, thus allowing the seal to pass fluid.
If you can pass fluid just by pushing back the piston, your in need of a rebuild.
If you have OEM lip seal pistons in your calipers, you should consider an upgrade to VBP O-ring pistons and seals. Inspect your SS sleeved lining of your caliper for any anomolies, assuming it has been rebuilt once before and has been sleeved.
Lip seals have a tendency to leak. VBP O-rings have less tendency, but can/will still leak over time, just seems less likely. Also take the oportunity to upgrade to SS sleeved flex lines from your frame to your calipers. You'll be happy with the more solid brake feel.
Have Fun......
Old Jul 12, 2009 | 05:01 PM
autimous's Avatar
autimous
I changed the front two calipers to the o-ring type, from Napa. It's amazing the difference it's made!
Old Jul 12, 2009 | 07:45 PM
OMF's Avatar
OMF
now just change the rears and you'll be set
Old Jul 18, 2009 | 11:18 PM
autimous's Avatar
autimous
Did the rears and discovered one stripped thread on each of the caliper mounting plates. So took it to a corvette place in the Bay Area and they put a helicoil in one side and cleaned up the threads on the other.
Long story short, I've now got exellent brakes! Thanks for all your input(except for 7t5: your mother obviously didn't love you enough as a child, and for that I'm truly sorry. But still, go f43K yourself)
Have a nice day
Old Jul 19, 2009 | 12:50 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lets put this in to a TRUE LIFE prospective!
My wifes 72 coupe developed a braking issue. She stated that the brakes felt funny and requested that I check them out. So,,,I drove it down the road and did some emergency braking stops and reported that the brakes are fine.
The next week, she drove the car down the hill and the brakes gave out due to a leaking rear drivers side rear seal.
So,,,I did a complete caliper / brake rebuild. The calipers had Stainless inserts. I ordered all the seals BRAIDED BRAKE LINES, new bleeders, replaced any deteriorated metal lines and rebuilt the calipers. I have a 100% success rate with the rebuild. The brakes stop MUCH better and the wife is HAPPY!
Do a complete brake system inspection and repair what needs to be fixed before you have the WRATH of someone..
Bill
To Leaking Caliper?
