Another carburetor question
Old Jul 9, 2009 | 03:19 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Default Another carburetor question
So, I ordered a new Holley 0-6210, a 650 cfm spreadbore carb for my car (1970, LS5). I am looking at the installation instructions, and the first instruction reads:
A steel reinforced gasket plus a thin stainless steel plate (used to cover the exhaust heat track or slot in the front of the intake manifold) can be found. Carefully remove both the steel plate and the gasket. Clean the manifold surface. Install the new gasked (gasket B), re-install the steel plate....If there is a standard type gasket with no stainless steel plate, replace this with the thin one supplied (gasket A)
Interestingly, when I took my old carb off, I had a gasket that looked like gasket B (meaning it was intended to have the ss plate) but no ss plate. Later in the instructions, it says this:
Holley Model 4165 (spreadbore) carburetors that have carbon deposits in the areas shown by the arrows (there is a picture here) will not be accepted for warranty. The deposit is evidence of improper installation (not using the stainless steel plate where required) for which Holley cannot assume liability.
So, given what I found, and that the mechanic said the carb wasn't working correctly because it had clogged with carbon, I'm thinking that whoever installed that carb didn't use the SS plate when they were supposed to, and ruined the carb. The question is, is there any way to be sure? Does anyone know for sure if I need the SS plate or not, or some way to tell by looking at the intake manifold or other location whether I need it or not?
Any other thoughts appreciated.
PK
Old Jul 9, 2009 | 03:23 PM
...Roger...'s Avatar
...Roger...
Whats your manifold look like where the carb bolts ? If it has that smily face groove going from side to side in the front then you need the SS.
Old Jul 9, 2009 | 03:29 PM
Derrick Reynolds
I'll take a close look (and a picture) tonight. Thanks.
Old Jul 9, 2009 | 03:32 PM
...Roger...
Here is a link with a manifold that needs it.You can see one end of the groove under the Edelbrock can.
http://www.lbfun.com/warehouse/tech_...ntake_Swap.pdf
Old Jul 9, 2009 | 04:04 PM
Derrick Reynolds
Excellent. Very clear now. Thanks!
PK
Old Jul 9, 2009 | 09:12 PM
Derrick Reynolds
I think I found the smoking gun. Looks like I need the stainless steel plate. See pic:
Old Jul 9, 2009 | 09:59 PM
noonie's Avatar
noonie
That's not the smiley face manifold. You don't need the ss plate.
The Smiley manifold has a slot ahead of the primaries that is only about 1/2" wide all the way across and has a hole at each end to the exhaust.
However, here in hot Florida, I do use the ss plate on all carbs, it helps with keeping the fuel a little cooler and prevent a little evaporation in this heat. It might be too cold though in the cooler temps up north.
You can get the ss at Advance Auto or Parts America online.
Old Jul 9, 2009 | 10:01 PM
...Roger...
Not sure now and I didnt realize you have a big block. The reason for the plate is to shield the carb from the exhaust that flows through the groove. On the small block at both ends of the groove are holes that are drilled through to the crossover exhaust.
Old Jul 9, 2009 | 10:14 PM
noonie's Avatar
noonie
Corvette engines
supposedly
66-68 327/300hp,
68 327/350hp
66-69 427/390hp
The 70BB might be one of those early-late deals, but the pic posted is not a Smiley.
Old Jul 10, 2009 | 10:21 AM
Derrick Reynolds
Here's what I am thinking: If I need it, and don't use it, I can ruin another carb within 600 miles. If I don't need it, and put one on anyway, is there any downside? Keeping the carb cooler and stopping some of the evaporation that stinks up my garage sounds like a good thing to me. So, unless there is some major downside, I am thinking of just ordering one, putting it on, and hopefully, being done with it.
Old Jul 10, 2009 | 01:16 PM
...Roger...
I don't see how it could hurt the carb but I also don't think not having it caused the black soot on your carb and intake unless it was causing the fuel to boil and making the engine run rich.The area under the primarys is clean so it must be sealed off already.
Old Jul 19, 2009 | 04:39 PM
Derrick Reynolds
Today, I finished the installation and tuning of a new Holley Spreadbore 650. I took it out for a ride, and unintentionally screeched the tires twice, so the car seems to be back(knock wood)!
Thanks for all the help! This forum has been an incredibly valuable resource for me on this continuing adventure!
Old Jul 19, 2009 | 07:08 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Glad it worked out. It really livened up my big block
Old Jul 19, 2009 | 10:40 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
The Holley spreadbore carbs are excellent for street use imho. I have the 4175 Vacuum Sec model and it is very crisp and responsive and the secondaries are fast and smooth!
To Another carburetor question
