1979 Battery Problem--need some help
Old Jul 30, 2009 | 10:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 72and86
I disconnected the battery and tested the 2 leads with the multimeter on ohms right? It reads 5.19 to 5.21
Does that help?
Steve
Heres the formula with the answer that you need. E= I X R
You know E = 12.2 VDC (common fully charged battery voltage)
You Know R = 5.3 Ohms
I = E/R E 12.2 VDC / R 5.3 = I 2.30189 amps
Thats a LOT more current draw than it should be. You should be drawing milliamps 0.02 amps
Old Jul 30, 2009 | 10:50 PM
72and86's Avatar
72and86
Hi Bill,
Do you have an English version of that?
And where do I start?
Steve
Old Jul 30, 2009 | 10:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your drawing 2+ amps at rest where you should be drawing almost nothing.
Like I stated earlier,,,C1,2 and 3 are easy. You can hook up your ohm meter to the disconnected battery leads and pull fuses ONE AT A TIME until the 5 ohm reading drops to zero. Then you find what in that circuit is drawing current.
If it were me,,,,,,,,,,I would start at the alternator. DISCONNECT the BATT wire on the back of the alternator and see if you still have the 5 ohms.
If not,,,,,Then go for the fuses.
BC
Old Jul 30, 2009 | 11:05 PM
72and86's Avatar
72and86
BC
Is that the single wire on the back of the alt w/the black boot?
Note: I did get a new Alt on ebay. Its on the way..
Thanks Bill.
Old Jul 30, 2009 | 11:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes! The one under the boot!
Old Aug 27, 2009 | 10:11 PM
72and86's Avatar
72and86
Update: Now the car dies after I start it and disconnect the battery.
So I installed a new alternator and viola the car started fine and guess what? I left the battery connected overnight (which I previously couldn't do) and it was NOT dead the next day.
Rebuilt Alt= problem solved... Thanks to all!!
Next: solving the elusive water firewall leak on both passenger and driver sides. Grrrr
Old Aug 27, 2009 | 10:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was at Carlisle Last year *Im here again now!!* and snapped these picture. Thay may help:
My recommendation would be to pull the carpet and trim, get a flashlight and GET ER DONE! Good luck!
BC
Old Aug 27, 2009 | 10:36 PM
72and86's Avatar
72and86
BC
The flashlight gig didnt work cause the leak is somewhere (on the sides) near or passed the top dome looking thing. Its coming from the sides. On the drivers side it leaks onto the clutch pedal.
Old Aug 28, 2009 | 12:50 AM
21boy's Avatar
21boy
Bill I wish my car did that so I could get to the engine bay without breaking my knees Glad the car works to the op, good luck with the water.
Old Aug 28, 2009 | 08:11 AM
...Roger...'s Avatar
...Roger...
So you feel the source of your battery drain was the alternator ?
Old Aug 28, 2009 | 09:42 AM
72and86's Avatar
72and86
yep. Seems that way.
