Rebuild Question
I know I want to smooth the block and turn it into a 383, also know that I want to keep the stock block in there, even if it's a 2 bolt.
Not sure wether to put in a flat tappet or roller cam in there though.
Anyway, on to the real thing I'm wanting an opinion on. Should I port and polish the heads myself and leave them on there? To not only keep it numbers matching, but since I am going for a sleeper look as well, or should I not even worry about the heads and just slap on a pair of aluminum heads? I'm not gonna make it a pure beast of an engine, since so much runs off of vacuum on our beloved c3's after all, can't really even cam it that high, so a 500hp 383 isnt my goal. I know I could paint the aluminum heads orange and all, but dont really like that look. I always thought aluminum heads should be shown off. Completely disregarding the fact I plan on painting the edelbrock intake I plan on putting on there orange however lol.
Anyway, which would you, if you were a potential buyer of the car see?
As far as paint, a layer of paint insulates. Keeping the heat in will decrease efficiency. It's your car. Do it your way. So don't let anyone tell you different.
I'm probably not even going to slap headers on it and keep the stock ram horns.
I can do the port work myself, but after I spend all the money on machining on the old cast irons I kinda thought I would be at aluminum head price anyway.
alluminum heads (no paint) biger the valves and runners the better it will be.
roller cam (not to big)
roller rockers
if i was a potential buyer i would want the cast heads to leave with me when i pick up the car.
it would be a waste of time trying to make those stock heads breath good enough for that moter-i agree with timat on that
The best overall approach for a budget solid-performing street 383 is using a late-model roller-cam block. They're relatively cheap, the bores are usually in great shape and you can almost always reuse the roller lifters and valley spider. A decent cast-crank 383 assembly with hypereutectic pistons shooting for 9.5 - 10 CR, overhaul the Vortec heads and put in a decent aftermarket hydraulic roller cam. Top it with a good dual-plane and carb, and you're right at 1 HP/CID flywheel or a bit better.
If you really want to build up from your existing engine, then the existing heads must go
They have the D-shaped "smog" chambers and absolutely dismal flow. Go with the same cast/hypereutectic rotating assembly, a decent set of aftermarket heads in the 180cc range and a mild cam. This will all bolt up to your existing intake, carb and exhaust manifolds and make around 340 FWHP - but some outstanding torque.If you're going to use exhaust manifolds, I would just do a straight 355 overhaul vs. building a 383.
These are real general answers to real general questions
