new engine wiring harness install
Old Jul 31, 2009 | 09:20 PM
my.yellow.74's Avatar
my.yellow.74
Default new engine wiring harness install
how much of a PITA is it on 74 coupe 350 auto trans. Mine has been hacked by Bubba in just about every possible way. Also, any suggestions on where to buy
Frank
Old Jul 31, 2009 | 09:33 PM
Gordonm's Avatar
Gordonm
Not as mich of a PITA as if the car burns because of this.
Seriously it is not a bad job. Just get a diagram and take your time. The engine harness is one of the easier ones to replace.
Old Jul 31, 2009 | 09:48 PM
TimAT's Avatar
TimAT
Both the engine and the forward light harnesses are a cakewalk.
I got them from thepartsladi. Lectric Limited harness OEM stuff Fit is great and all factory looking- just new.
Old Aug 1, 2009 | 10:55 AM
Alan 71's Avatar
Alan 71
Hi Frank,
I'll agree too.
The engine harness is the easiest to change.
Lectric Limited.
Regards,
Alan
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
very easy job.....now Interior harness replacement is a whole differnt answer.
69VETT
Old Aug 13, 2009 | 01:25 PM
loquinho's Avatar
loquinho
Is the starter run off the engine wiring harness? I've also got a '74 350 (also yellow!), and I have a short in the starter or starter solenoid wiring. I'd like to just replace the wires, but not sure how involved it is to do this.
Old Aug 13, 2009 | 01:51 PM
...Roger...'s Avatar
...Roger...
Yes the starter is part of the engine harness but you can repair it .
What do you mean by SHORT ? Whats it doing or not doing ?
Old Aug 13, 2009 | 10:47 PM
loquinho's Avatar
loquinho
Turn the key, I hear a fan start to turn somewhere (it's quiet, so probably the cabin air fan), interior lights dim a little, silence from the engine bay other than the fan - that's what I get. Until recently, fiddling with the wires going into the starter solenoid caused it to fire right up. This last time, it took over an hour and a prayer to get it going, and I still don't know how it did it.
Last edited by loquinho; Aug 13, 2009 at 11:00 PM. Reason: Edited For Clarification
Old Aug 13, 2009 | 11:51 PM
...Roger...
You could just have a loose connection at the starter. Also on your 74 you have the seatbelt interlock relay on the passenger side firewall that the purple starter wire run through. Moving the wires at the starter could be moving those as well.
Old Aug 14, 2009 | 02:28 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I was scared of wiring, but mine was pretty hacked. I laid out the new harness next to the car in its general position. The installation was very straightforward. I cautiously turned the ignition key for the 1st time... She fired immeadiately and idled (purred) like never before. Go for it.
Old Aug 14, 2009 | 04:39 PM
rajsid's Avatar
rajsid
Do you have to remove the dash to change the engine wiring harness?
To new engine wiring harness install
