Car stumbles under load.
Old Aug 2, 2009 | 12:25 PM
eastltd's Avatar
eastltd
Default Car stumbles under load.
Hi Guys,
A little help if you would please. My car stumbles above 3000RPM. It sounds like the ignition is stuttering but I think it may be fuel starvation.
I have a 454 with an Edelbrock performer carb. The ignition is MSD with a 6000RPM chip.
I just changed the fuel pump inlet hose to a preformed "S" type thinking the old line may have been pinched. No change!
Is it possible the return line is pumping too much fuel back to the tank and starving the carb?
Old Aug 3, 2009 | 09:54 AM
eastltd's Avatar
eastltd
ttt
Old Aug 3, 2009 | 09:56 AM
eastltd's Avatar
eastltd
Update:
I tested the car with the return line pinched off. No change. I still get the stumble above 3000RPM.
Any suggestions?
Old Aug 3, 2009 | 10:06 AM
73StreetRace's Avatar
73StreetRace
Does the engine rev freely ( in neutral ) above 3000 RPM or not ? This could indicate if it is ignition or fuel related.
What kind of carb do you have ?
Vacuum secondaries or DP ?
Did you check fuel pressure and float levels ?
Do you have a fuel ( and possibly clogged ) filter ?
Does it stumble the same if you punch the throttle hard and if you do it progressively ?
What kind of distributor do you have ( points or electronic/magnetic pickup ) ?
Old Aug 3, 2009 | 10:52 AM
Jims66's Avatar
Jims66
What's your fuel pressure at "Break-up" ???
Old Aug 3, 2009 | 11:58 AM
Rich's'78's Avatar
Rich's'78
when did you last change the plugs? I had this once, plugs looked fine but changing them solved the problem (they hadn't had much use either!).
Also check your gas tank is venting.
Old Aug 3, 2009 | 12:21 PM
bluthundr's Avatar
bluthundr
I was finally able to confirm my fuel starvation problem by putting the car in neutral, reving it up and holding it until it started to stumble, then shutting it off immediately and pulling my bowl sight plugs. Sure enough the primary bowl was empty and I concluded that the fuel pump was not keeping up with the engine.
Old Aug 3, 2009 | 04:07 PM
eastltd's Avatar
eastltd
Thanks for the input guys. Everything is brand new so I'm going to start with measuring the fuel pump pressure and then move on to the carb.
This is the first Edelbrock carb I've owned so I'll have to study the manual and take it one step at a time.
Old Aug 8, 2009 | 06:03 PM
Jack Wood's Avatar
Jack Wood
Default If it's a 600 cfm Performer then it's not enough.
454 CID X 6000 rpm divided by 3456 X 90% = approx. what you need in cfm for a streety.
To Car stumbles under load.
