'73 rear quarter different than '72?????????
Old Aug 3, 2009 | 12:14 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Default '73 rear quarter different than '72?????????
HI
DOES ANYONE KNOW IF '73 REARQUARTERS ARE THE SAME AS '70-72?
IF THEY ARE DIFFERENT, CAN SOMEONE TELL ME THE DIFFERENCES?
AS ALWAYS, THANKS IN ADVANCE.
BILL SR
Old Aug 3, 2009 | 02:26 PM
wombvette's Avatar
wombvette
Same.
Old Aug 3, 2009 | 03:09 PM
Streamline's Avatar
Streamline
I maybe wrong on this......(perhaps the fiberglass folks can answer) I thought the manufacturing process for the panel changed in 73...press molded. This is not gospel.
Old Aug 3, 2009 | 03:25 PM
lakebumm's Avatar
lakebumm
OK GUYS.
THANKS FOR THE REPLIES.
BILL SR
Old Aug 3, 2009 | 05:06 PM
zwede's Avatar
zwede
All C3 panels were press molded.
Old Aug 3, 2009 | 06:52 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Yes the panels are the same as mentioned.
Not meaning to be a "stickler"
Press-molded is not a generic term. It is specific to a type of process used for manufacturing fiberglass panelks of a certian era(s) of Corvettes.
NOT ALL C3 panels are press molded, because NOT all C3 panels are fiberglass.
You have "presses molded" and RIM (rapid injection molded)
Fiberglass panels like those of the quarters in question are press-molded.
But when GM went to using SMC (sheet molded compound) the process of making them changed also. and also the material and resin. The two are COMPLETELY DIFFERENT. This is NOT my opinion...it is FACT.
All C3 panels from the factory were made from molds. a male and female mold..lets say. when put together and gauged they maintained a specific thickness.
BUT the process in making "press molded fiberglass panels" and SMC panels is completely different.
If any want to know more. Look it up on the net or ask meor any Corvette bodyman on the forum. Just trying to inform those correctly instead of allowing an accidental typo so send the wrong message.
"DUB"
Old Aug 3, 2009 | 08:43 PM
wombvette's Avatar
wombvette
I know you know your stuff, GrandMaster, but SMC was and is, press molded, as far as Corvette panels were concerned. The first SMC panel was used in `71 and just happens to be that same rear quarter fender. All of the earlier versions of corvette fiberglass that fender came in, polyester glass(1968-69), Gennite 70-71, and SMC (71-73) were all press molded, but used different base materials.
The one injection molded part that comes to mind sold by GM to use on a Corvette body was that 67 BB abortion that they sold over the counter for a time. It was terrible.
Old Aug 3, 2009 | 10:14 PM
wombvette's Avatar
wombvette
Default If you would like to see SMC being Made.
This is the company, MFG, that made many panels for the early Corvettes. You will see their logo on lots of midyear panels.
http://www.youtube.com/watch?v=dXLlDF5DeaU
Old Aug 4, 2009 | 04:23 AM
Solid LT1's Avatar
Solid LT1
Starting in 1973 model year Vette body panels were made from SMC (sheet mold compositie material) before that all panels were press mold construction. SMC uses different bonding techniques/chemicals than PM panels, the 2 don't work very well together. Corvette Image in Oregon makes correct style PM panels for our C3 Vettes towards the end of avalabilty GM panels were SMC construction evan for the early C3 panels, you can construct a real "Handgrenade" by combining the 2 types of panels on a Corvette resotration.
Old Aug 4, 2009 | 09:15 AM
wombvette's Avatar
wombvette
The first SMC panel on a Corvette was the later 1971 Quarter Panel. The first all SMC body paneled Corvette body was 74. The 73 still had the rear upper deck in the old type polyester fiberglass. And, I repeat for the umpteenth time, They were all pressed molded. That only refers to the pressing two matched molds together. The SMC panels were made the same way as the old panels. The materials were changed. SMC is fiberglass strands sandwiched by semi-cured resins in between two sheets of thin plastic. The sheet is placed into the mold. The mold is closed and the resin is thermo-set. Watch the video. If you use the correct bonding agents and finish materials for SMC, there is no reason it cant be used in conjunction with the old fiberglass.
Old Aug 4, 2009 | 04:37 PM
Alan 71's Avatar
Alan 71
Hi,
I believe you can see the slight difference in the appearance of the 2 materials used in 71 in these pictures.
Regards,
Alan
This is an early January built body. (6589)
Old Aug 4, 2009 | 08:58 PM
Former Vendor
The processes are different. ONE IS PRESSED the other has resin injected into it. The only reason I know this is that one of my customers made the top hood surrounds for GM and described the process on how it went and how quickly they could make parts. SO SMC is not being pressed together, the molds are joined with the pre- material inside and then the resin is injected so to speak. I called him today to just verify how it was done.
I will watch the video...and eat my words...and stand corrected... if it is anything different. I am able to admit when I am wrong and would be surprised that all these years I have been told an un-truth and thought it was the truth.
"DUB"
Old Aug 5, 2009 | 10:18 AM
AutoX-Z06's Avatar
AutoX-Z06
Good post!!
Old Aug 5, 2009 | 11:12 AM
Richard454's Avatar
Richard454
Disclaimer: I'm not a NCRS judge-haven't had an original rear quartered 73 right next to a 72 and I did NOT stay in a Holiday Inn Express last night-
I heard from a knowledgeable original 73 owner that the mufflers on the 73 were larger 7 x 9 oval versus 5 x 9 oval AND the exhaust was CENTERED in the exhaust tips. With these changes- the underneath of the rear quarter was cut in a bit versus the previous years.
So -I'm going to say they were different.... but just slightly...
Richard
PS- I just looked in a Dr. Rebuild catalog and it does list different mufflers and hangers as well as the tips for the 73.
To '73 rear quarter different than '72?????????
By Michael S. Palmer | 2026-06-03 09:39:05
