Rear Body to High
Old Aug 6, 2009 | 01:16 PM
76yellow's Avatar
76yellow
Default Rear Body to High
How do I lower the rear body on my 68 ? Longer bolts ? And where can I get them ?
Old Aug 6, 2009 | 01:52 PM
Rally68's Avatar
Rally68
Duntov sells a kit with bolts that are 2" longer than stock
Old Aug 6, 2009 | 01:54 PM
72LS1Vette's Avatar
72LS1Vette
Some hardware stores and home centers will have grade 8 bolts that are a couple of inches longer than the stock ones.
Rick B.
Old Aug 6, 2009 | 02:27 PM
joewill's Avatar
joewill
I had looked and looked at all the local hardware stores, I found lots of 8 and 10 inch bolts.. but none are grade 8.. vbp has kits, so you might have to go that route....
http://www.vbandp.com/detail.aspx?ID=443
Old Aug 6, 2009 | 03:36 PM
kunkle's Avatar
kunkle
I used these bolts for a C4 from midamerica- 10.5", grade 8. Someone told me about it long time ago.
mamotorworks.com/corvette?frame=3.1085
Old Aug 6, 2009 | 03:42 PM
Alan 71's Avatar
Alan 71
Hi 76Y,
Many towns have a commercial fastener company like FASTENAL. They have or can quickly get a good supply of grade 8 bolts.
Regards,
Alan
PS: You do need to be careful that the bolt doesn't get too long. The longer bolts allow the outer tip of the long spring leaf to get very close to the inside lip of the wheel.
Old Aug 6, 2009 | 03:51 PM
76yellow's Avatar
76yellow
Thanks alot guys !
Old Aug 6, 2009 | 10:01 PM
c3_guy's Avatar
c3_guy
Van Steels has them. They are good guys and there prices are reasonable http://www.vansteel.com/index.cfm?fu...&SubGroup=1502
Good luck
Old Aug 6, 2009 | 10:11 PM
...Roger...'s Avatar
...Roger...
Willcox has some 8" long.
http://willcoxcorvette.com/product_i...ducts_id=15848
To Rear Body to High
