Replacing a torque converter
Old Aug 6, 2009 | 06:57 PM
thiatt's Avatar
thiatt
Default Replacing a torque converter
Has anyone ever replaced their torque converter? I am considering adding a stall to my 1977. Is this possible with out doing a body lift?
Old Aug 6, 2009 | 07:26 PM
Gordonm's Avatar
Gordonm
Yes just remove the transmission. You have a removeable cross member which makes it easy. You may not even have to drop it all the way out. Just move it back and lower it slightly and the converter will come out. Very easy to do on a lift, slightly more challenging on the garage floor on your back. The transmissions are quite heavy at about 200 or so pounds.
Old Aug 6, 2009 | 07:31 PM
thiatt's Avatar
thiatt
Thanks, I was hoping it was possible in that fashion, replaced a thunderbird tc that same way.
To Replacing a torque converter
