Fuel line help
Old Aug 8, 2009 | 09:03 PM
sonny_burnett's Avatar
sonny_burnett
Default Fuel line help
I am having some problems with my car, I think the problem was the filters in my carb (sintered brass), which I just replaced. Before I start it up I wanted to add an inline filter but I don't know which line is the inlet on my pump. I have a mechanical fuel pump with 3 ports, one goes to the carb, that one is no problem obviously but between the other two I can't figure out which is inlet and which goes back to the gas tank as an outlet. One has a sqaure boss on the bottom of the pump and the other is a 90 degree tube sticking out. Any help is appreciated I would like to get this done tonight if I can. Thanks.
Old Aug 8, 2009 | 09:18 PM
sonny_burnett
There are 2 lines coming from the gas tank, one on the bottom and the other line I assume from the top, anyone have a gas tank diagram for a 71?
Old Aug 8, 2009 | 10:15 PM
sonny_burnett
One line comes out of the bottom and the other is on the side of the tank about half way up, the line on the bottom is a larger diameter. Anyone know which is tank return?
Old Aug 9, 2009 | 03:49 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
The supply line is 3/8. The return is 5/16.
To Fuel line help
