Headlight washers
Old Aug 10, 2009 | 09:36 AM
crisko's Avatar
crisko
Default Headlight washers
Does anyone know how to wire a headlight washer pump to the windshield washer pump on a 1969 vette.I have the hoses hooked up but these wires are not on my wiring diagram.Thanks Crisko
Old Aug 10, 2009 | 12:38 PM
GunPowder's Avatar
GunPowder
There is no separate headlight washer pump, there is one pump to serve windshield and headlights and a "valve" (on driver's side of the wiper motor) to distribute water between windshield and headlights.
So do you mean the main pump?
Somewhere on the forum is a post with some pictures explaining the 69 washer pump principles - but can't find it right now.
Old Aug 10, 2009 | 02:20 PM
crisko's Avatar
crisko
Yes I mean the valve.I need to wire in the solenoid.
Old Aug 10, 2009 | 04:05 PM
GunPowder's Avatar
GunPowder
it's a yellow and a dark-blue wire. You can find them in AIM wiring diagram (p. 293) near the wiper motor (two pin connector).
Old Aug 10, 2009 | 04:31 PM
crisko's Avatar
crisko
Thanks. That brown plug with the yellow and blue is now on my pump. I guess I remove it and plug it on the solenoid.One more ques.What wires go back to the pump.
Old Aug 10, 2009 | 04:42 PM
GunPowder's Avatar
GunPowder
Both black wires go back to the pump
Old Aug 10, 2009 | 04:51 PM
crisko's Avatar
crisko
Thanks GunPowder for your help.The pics will make it easy.All I need to do is make up 2 blks.
Old Aug 11, 2009 | 07:52 AM
Young69Owner's Avatar
Young69Owner
Gunpowder, thanks! I have everything all set up except for the yellow plastic piece on the right that goes through the anti-drip solenoid. Any idea where I could get it? Did all '69s have headlight washers?
Old Aug 12, 2009 | 09:55 AM
GunPowder's Avatar
GunPowder
Sorry, have no idea where to get spare parts for 69 wiper motor/washer pump. I know they are very rare. You could ask Willcox or Paragon, they may have some refurbished parts?
AFAIK all 69 did have the headlight washers - disappeared 70 or 71.
Old Aug 13, 2009 | 11:44 AM
Young69Owner
Okay, so '69 is the one with the 4-port washer/anti-drip solenoid. Some '70s and '71s had the rare 5-port washer pump. I had to buy the whole solenoid from Melrose T-Tops for $150 - that was the best price I could find. They are sending me a diagram too, because it looks to be a messy setup.
To Headlight washers
