A/C Pressure
Old Aug 16, 2009 | 10:33 AM
DJCorn's Avatar
DJCorn
Originally Posted by Ganey
A vacuum should be done on the system before adding freon.
Sorry, left that part out, he did pull vacuum on it before he started adding freon.
We haven't worked on it all weekend, hopefully he'll be back over tomorrow to work on it.
Old Aug 16, 2009 | 11:29 AM
noonie's Avatar
noonie
Originally Posted by nelsoncomp
If you have converted to R134 you will need to change the pressure switch from an R12 to an R134 pressure switch. Its avaiable at any parts store. The pressure in 134 is highter than in R12 systems........
Let me know if you need any more help.
NelsonComp
74's didn't use a "cycling" switch.
"Pressure switches" were only required to prevent high side blow off on 134 conversions done properly.
74 used a vir system and the valve is probably sticking and/or the desiccant bag has let go and floating around in there.
Get your buddy to get you a vir assembly and go back to 12 or convert properly to 134 and adjust the valve in the vir (if possible) or go with a later OT evaporator or even an eliminator kit.
Please describe exactly what was done to convert to 134
Still need ALL the pressures to give you a good guess.
Old Aug 21, 2009 | 12:29 PM
DJCorn's Avatar
DJCorn
GOT IT WORKING!!!!!!
So on compressor number three he desided to just use a couple of can's of R134 instead of a box of it that he had. He said what he think was happening was that too much of the liquid was getting into the system. After bolting it in, pulling vacuum, and slowly putting in a couple of can's to 45 lbs, its working like a champ. He thinks that my compressor switch may be going out, he noticed that the compressor wasn't shutting off when I turned it off in the car, it did shut off when I turned off the car and restarted it though.
