A/C Pressure
Old Aug 10, 2009 | 01:08 PM
DJCorn's Avatar
DJCorn
Default A/C Pressure
What should the A/C pressure be on a 74 after the R134 conversion? The guy that I had work on my A/C said that the pressure was @ 50. Is that too high? I'm trying to figure out what is causing the compressor to squeal. The only difference with before it was putting out hot air (and not squealing) and now is that he put refridgerant in it.
Old Aug 10, 2009 | 03:35 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Somewhere between 30 and 40 on the low side, 200 to 250 on the high side. These are not carved in stone, as there are variables that effect the pressures, but this will get you in the ballpark.
Old Aug 10, 2009 | 04:12 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
50 sounds right for R-12.
I have seen 134 as low as 25 and still cool good.
I skimmed the other thread and wonder what is happening.
Seems if the compressor pushes 50lbs of 12 that 50lbs of 134
would be the same even though it might not cool right?
I am not sure the pressure is the issue.
Old Aug 10, 2009 | 09:04 PM
wnmech's Avatar
wnmech
There are a lot of variables on your conversion. If your outside air temp is up around 90 degrees and you have only the engine driven fan moving air across the condensor then 50 on the low side is about normal and around 250 on the high side should be normal. R134 runs higher pressures than the r12. The more air or the cooler your condensor is the lower your pressures will be. How old is your compressor? Did your mechanic flush out the system and old oil? Your old compressor may not be able to handle the higher pressures and you may have to relieve a little bit of refrigerant.
Old Aug 11, 2009 | 09:28 AM
Ganey's Avatar
Ganey
DJCorn
Assuming your A/C guy knows what he is doing, tighten the belt.
Pressure depends on temp., car, etc.
50 sounds high if at idle.
I am not running R134.
Since R12 was brought up:
R12 at idle about 30 low side will do it.
Old Aug 11, 2009 | 11:43 AM
noonie's Avatar
noonie
To even make a wild stab at this you have to supply a lot more info
Ambient temp
Inside vent temp, blower high
low side pressure @ 1500rpm
high side pressure # 1500 rpm
If it was 50 psi on the low side at idle that is way too high for either refrigerant.
On the high side , it would be way too low.
Old Aug 11, 2009 | 03:27 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Is it 50 without the compressor running or with stopped?
If it is when running, it would be 10lbs min high with 134.
Easy enough to release pressure.
R12, 50lbs running is @ the cutoff for testing.
Could be restriction between high and low pressures.
Old Aug 11, 2009 | 03:47 PM
08vycpe's Avatar
08vycpe
To add to what was said above, keep in mind the pressure is higher when the A/C is off than when it is running. 40-45 low side on an average summer day with A/C running seems about right.
If you converted to R134a keep in mind that the original R12 oriface tube is not the best choice for newer R134a systems. The oriface tube is what regulates the pressure between the high side and the low side.
Have your A/C guy take a look at the oriface tube for contamination on the screen or metal chips from the compressor failing. I would recommend replacing the original oriface tube with one of the new variable ones. The original oriface tube can be replaced from $0.88 to $4.50 depending on who you purchase it from. A new variable one would be $20-$30 but the cooling difference is worth it. You will loose your charge when the oriface tube is removed. Use a tool designed for this purpose (in and out) or you could break it off in the metal tube. The plastic is delicate and many decades old so it is brittle and breaks easily.
The squeeling sounds like your belt. Either the belt is loose or the compressor is laboring or failing putting a larger than expected strain on the belt.
Old Aug 11, 2009 | 10:16 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Ambient temp
Just for starters do a search for a pressure/temp chart for both r12 and 134A you will see that the working pressure and temps are not that different. The idea here is to get the pressure down to a point were the temp will be just above freezing at the evaporator so the condensate will not freeze on the coil but produce the coldest temps possible, but keep in mind that you have to consider ambient temps in the car and at the condenser, there are many other variables to consider here also. Supply the needed info and someone here will offer a little better insight on your question.
Neal
Old Aug 11, 2009 | 10:30 PM
LT1driver's Avatar
LT1driver
if 134 you use only about 80-90% of r12 refrigerant amount.
Old Aug 12, 2009 | 08:57 AM
DJCorn's Avatar
DJCorn
Originally Posted by Ganey
DJCorn
I tightened the belt, then I replaced the belt. The sound seems to come from the clutch area, the pulley spins freely. He told me it was 50 at idle. I just had him order a new compressor, if this doesn't fix it then I'll take it to a shop. He is a coworker of my wifes and sells car parts on the side out of his Dad's shop or something. He agreed to come over and fix it just for the price or parts but its looking like I need to take it to a specialist. I just really don't want to fork over $1k for someone to fix it.
Old Aug 12, 2009 | 09:03 AM
tommyleea's Avatar
tommyleea
Are you using the gauge set with high and low pressure gauges? You need to have both readings to troubleshoot or interpret A/C pressure readings, in my opinion. Cheers.
TommyJ
Old Aug 12, 2009 | 09:17 AM
Ganey's Avatar
Ganey
If you are hearing a chirp, it's the belt. 50 low side is too high at idle. You can try to watch the front of compressor to see if it is trying to lock up- taking some freon out could do it.
Old Aug 12, 2009 | 09:42 AM
DJCorn's Avatar
DJCorn
I don't think it is a chirp, it is a loud, non-stopping, squeal. I can see on the front of the compressor that it is trying to lock up. So basically I have to take it to a shop for them to remove some of the freon and see if that works? I really don't want to drive down the road with that screaming sound coming out form under the hood.
Old Aug 12, 2009 | 01:47 PM
chevymans 77
Its possible that the clutch needs adjusting, take a set of feeler gauges and gauge the gap between the clutch faces. I'll need to look up the correct gap but I think its around .020" on the R4. This gap doesn't usually need adjusting. If the faces are slipping than I would verify the voltage to the clutch coil and verify high side pressure. Check the voltage using the groaund at the comp. If its been this way for a while than its possible the clutch faces are distorted enough that they will need replacing. The clutch and clutch coil can be replaced without compromising the system. Its possible to do it with the comp installed in the car.
Neal
Old Aug 14, 2009 | 08:16 PM
DJCorn's Avatar
DJCorn
Okay, so he came back over with a new compressor and after he put oil in and spun it some, we reinstalled. Then we started adding freon. It ran great for like 10 minutes, blowing cold air, then it started making that obnoxious squeal (skreech) again. What could cause a brand new compressor to do this as well? The clutch area got really hot and started locking up. He also said that all of the sudden the pressure spiked on the low side. He kept releasing pressure to see if that was causing it but the skreech didn't stop. HELP!
Old Aug 14, 2009 | 08:50 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
when you first put freon in, did the clutch cycle quickly or did it engage and not turn off?
I am thinking there is a blockage that gets pushed
or your pressure switch.
To A/C Pressure
Old Aug 15, 2009 | 06:33 AM
Ganey's Avatar
Ganey
Okay, so he came back over with a new compressor and after he put oil in and spun it some, we reinstalled. Then we started adding freon. ... HELP!
A vacuum should be done on the system before adding freon.
Old Aug 15, 2009 | 11:38 PM
nelsoncomp's Avatar
nelsoncomp
5th Gear
If you have converted to R134 you will need to change the pressure switch from an R12 to an R134 pressure switch. Its avaiable at any parts store. The pressure in 134 is highter than in R12 systems. Here is the formula when doing A/C charging and using 134.
Check the current outside Temp from a valid source. Low side should be 30 less. Outside temp makes a huge difference on pressures. On an average 50 is a good mark if it is really hot out like 95, fill it to 50 and let it set there. Start filling it while watching the pipes when they start sweating you are close. Only fill a little bit at a time as the pressure on the hisgh side and low side will adjust as freon is added.
Remember it will not get really cold until you start driving it and air starts hitting the condenser. A perfectly tuned harrison A/C unit will cycle on and off after running for 20 min and the pipes are sweating good.
Let me know if you need any more help.
NelsonComp
Old Aug 15, 2009 | 11:39 PM
nelsoncomp's Avatar
nelsoncomp
5th Gear
You have to pull vaccum on the system if you opened it up. The system is air locking and causing the compressor to lock up.
