This engine came from T&L engines and has serious problem with detonation and strange sounds, we pulled one of the heads and found these issues:
Shouldn't the piston be square to the engineblock, there's a .011 difference on number 2 cylinder ?
this is cylinder 4 with less than 100 miles on it:
cylinder 2 when piston is at the top, notice the cylinderwall clearance:
when the piston is at the bottom at cylinder 2 it looks like this, the cylinderwall clearance looks bigger:
I can see a slight difference top to bottom but there shouldn't be any side to side. If it looks like there's more gap when the piston is down maybe the taper is just way too much. What did T&L say about your situation?
The piston crown is a usually a lil smaller than the skirt. If the block was not zero decked, it is normal for the piston to not come all the way to the top pf the cylinder. I dont see a problem in thses pics (IMO). BB72, I think the difference you see is looking at the reflection on the cylinder wall that you cant see when the piston is on top.
But shouldn't the distance to the deck be the same from the top of the piston, on this piston there is a difference to deck of .011 inch facing front and facing rear ? or I'm I missing something
If you mean the piston is .011 below the block surface, that is about normal. It will not be exactly the same if it hasn't been zero-decked. Check your T&L paperwork and see if they give you that measurement.
Um, that bottom picture looks more than a little wacky. Yes, pistons have slight barrel to them and they do rock in the bore, but the gap I'm seeing in that bottom pic looks crazy - it looks like you can see a good bit of the ring; is that what I'm seeing?
I see what you mean BB now. Pitch the feeler gauges and clean the surface and use a depth gauge on it. I just noticed the .021 and the .010 on the feeler gauges.
I see poor machine work, and poor assembly work, and I see a company that needs to send you a new engine.
The wear in that cylinder is atrocious, the deck of the block should not be that far off from one point to another, not to mention just that one cylinder, the bore of that cylinder is definately way off base, but I agree that I see no signs of detonation.
Whoever machined and assembled that block must have been off their meds that day. I would kindly get a new engine sent to me, and they pay the freight, or a total refund and learn never to do business with them again.
The deck shouldn't be off that much across the bore. The factory gets them straighter than that; factory is typically around 0.020" below the deck. The surface looks like a typical factory broached deck. It definately hasn't been cut at a machine shop. Are you sure you're getting an accurate measurement? IE - the 'straight edge' is actually straight or there is gasket material interfering with the measurement?
The cylinder wall looks tapered & I don't see any marks on the pistons indicating an overbore size. I can just about guarantee this was a typical KRYLON rebuild. Maybe you got lucky and yours actually has new rings & bearings.
