Should there be underbody heat shields on a 72?, mine does not have them. I'm just getting mine on the road after hauling it home on a trailer 10 years ago, seems to be alot of things missing or changed. Luuckily most of it is minor.
I posted this on factory correct resto, but not much activity there, hope its OK to post here.
Hi Mike,
I believe your 72 had:
A foam collar wedged between the bell-housing and the transmission tunnel.
A foil covered underbody tunnel insulator.
2 'U' shaped dense foam shields on the frame rails just behind body mount bracket #2.
2 small dense foam triangles that wedge alongside the frame and body at the toe boards.
I believe that's it.... the interiors were still pretty hot, especially with BB engines.
Regards,
Alan
Thanks for the replies, this forum has answerd many questions for me although this is the first time I asked one. I look on here every day and it has been very helpful.
