I assume the car runs, did you rotate the dist whil the timmimg light was hooked up?
Yes the car runs.
I set the timing manuelle with out a timing light, the timing is (I think) from 14-18 BTDC. and the car runs good, I have no problem there.
I should have paid closer attention. If memory serves, the MSD docs will tell you not to use a Dial Back or Digital timing light. I've used the old fashioned inductive timing lights on MSD before, that should work.
If you call MSD, don't be surprised if they try to sell you a timing light.
Can I disconnect the 6AL box, and wire from the distributor to the coil, and set my timing, and then connect to 6AL box again? (I guess that it is the 6AL box that gives me problems)
Can we assume your using the battery in the car as a power source and not using an external battery not connected to the car?
Always looking for the obvious answer.
Douglas in Green Bay
Yes I use the battery in the car.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I've had a digital dial back timing light connected to my MSD for years. Something is not right, clamp the inductive clamp on number 1 wire near the distributor, put the positive wire on the positive terminal of the alternator and negative wire on the negative terminal, turn the light on and start the motor.
Have you got that metal braided spark plug wires or something like that ?
I've tried that, it dosen't work.
I've also sent a mail to MSD, let's see what they can find out.
What I was thinks of is, go from distributor to the coil, cut the cable to the 6AL box, and connect the cable to the coil. Can this work?
I have Moroso Blue Max spiral conductor wires http://www.moroso.com/articles/artic...piralCore.html on my '69. My Penske (Sears) inductive dial-back timing light will not light with theses wires. When I time the car, I substitute a plain old carbon core wire on #1 cylinder, and the light works fine. When I'm finished I reconnect the Blue Max wire and it's good to go. I don't know if this is your problem, but it's easy enough to check. You don't have to remove the #1 wire from the car, just unplug it at the distributor and the spark plug and plug in the substitute wire.
Hi PeteZ06
I just tried your suggestion, unfortunately it dosen't work.
But thanks for input.
I have a dial back timing light, an MSD 6AL box, blaster coil, 8.5mm MSD spiral wound wires and MSD distributor.
I have to be sure the clamp on the #1 wire is near the spark plug and gripping the wire in the clamp opening just right or I don't get a spark.
MSD advises that because of the multiple spark over 20* of rotation, SOME dial back lights will not work properly and it will look like the timing is floating all over the place when it is actually the timing light. It will however still show a flash and the flash will sometimes look random. If you get no flash at all and the light works on other cars it must be your connection.
Try another spark plug wire to see if you get a flash.
The worst case scenerio would be to put degree tape on the harmonic balancer so you can set base, vacuum and mechanical timing accurately with a non dial back and non digital timing light.
Make sure you've got the timing light leads hooked up right. I had the same problem and then felt like an idiot when I found out I was hooked to the wrong battery terminal.
