Problem setting timing in my car.
Old Aug 20, 2009 | 02:36 PM
  #41
c3_dk's Avatar
c3_dk
Originally Posted by 08vycpe
I have a dial back timing light, an MSD 6AL box, blaster coil, 8.5mm MSD spiral wound wires and MSD distributor.
I have to be sure the clamp on the #1 wire is near the spark plug and gripping the wire in the clamp opening just right or I don't get a spark.
MSD advises that because of the multiple spark over 20* of rotation, SOME dial back lights will not work properly and it will look like the timing is floating all over the place when it is actually the timing light. It will however still show a flash and the flash will sometimes look random. If you get no flash at all and the light works on other cars it must be your connection.
Try another spark plug wire to see if you get a flash.
The worst case scenerio would be to put degree tape on the harmonic balancer so you can set base, vacuum and mechanical timing accurately with a non dial back and non digital timing light.
Hi,
I just tried both, and nothing is working, I even took of the rubber of around the cable in the spark plug end (AV ) and still nothing.
Old Aug 20, 2009 | 02:40 PM
  #42
c3_dk's Avatar
c3_dk
Originally Posted by Big Don
Make sure you've got the timing light leads hooked up right. I had the same problem and then felt like an idiot when I found out I was hooked to the wrong battery terminal.
Hi,
I connect the red to the red on the alternator, and I connect the black to a good ground.
Old Aug 20, 2009 | 03:38 PM
  #43
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Originally Posted by c3_dk
Hi,
Ok, take a deep breath This is starting to sound like an easter egg hunt.
Hopefully you have another car...
  • Establish a known good timing light by testing it on another car.
  • Remove #1 plug wire from the vette and test it on the other car to establish a known good wire. Leave it there for now and:
  • With the #1 wire working on the car where the timing light was verified, verify the timing light with the #1 plug wire.
Now you KNOW that:
  • the light is good
  • the wire is good
  • the the light on the wire is good
  • and you already know you have spark on the vette.
That ONLY leaves you with an issue with the MSD. If you can bypass the MSD and still get spark, that would be the next step. Maybe you need to put an old fashioned SSD coil in while setting the timing - easy enough.
Robb
Old Aug 21, 2009 | 12:23 PM
  #44
DJCorn's Avatar
DJCorn
I had the same issue with a craftman not working, i went to Autozone and got one of their digital timing lights and still had a problem. Then I hooked jumper cables to the battery and my timing light to it, worked like a champ.
Old Aug 23, 2009 | 06:24 AM
  #45
c3_dk's Avatar
c3_dk
Now you KNOW that:
  • the light is good
  • the wire is good
Robb
Thanks Robb,
The cables and triming light works, I know that because I had no problem with my "old" HEI when setting the timing.
I will try with a SSD coil also.
Old Aug 24, 2009 | 10:54 PM
  #46
AWilson's Avatar
AWilson
Old Aug 30, 2009 | 01:40 PM
  #47
c3_dk's Avatar
c3_dk
Today I found my +20 year old timing gun, it a $15 model. AND IT WORKED, so now I could set my timing to 20 degrees. :-)
And the Innova 5568 can stay in the box !!!!
So if anyone has the same problem, find an cheap old timing gun............
Old Aug 30, 2009 | 11:22 PM
  #48
OMF's Avatar
OMF
Glad to see you found the problem.....everyone will learn from this
Old Sep 1, 2009 | 04:16 AM
  #49
73StreetRace's Avatar
73StreetRace
Yes, sophisticated devices are sometimes piece of ****.
Too sensitive, too complicated, too fragile...
The simplest, the best...
Old Sep 12, 2009 | 11:57 AM
  #50
c3_dk's Avatar
c3_dk
Yes keep it simple
