Wandering c3 Vette
Old Aug 21, 2009 | 01:00 AM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by Krystal
Rear trailing arms
Bushings.
People often overlook the back of the car when thinking about problems like this.
You wouldn't be the first person who replaced and aligned everything up front ....... and then found the real problem was in the idea that it was the back wheels that were all over the place.
Replaced both arms completely just so we wouldn't have to deal with this again but when the bushings in the front of your trailing arms go bad like mine were.......the car drives EXACTLY like what you are describing.
Seems like you have replaced or checked everything else so I agree, this is where to look to correct the problem. Have the front trailing arm bushings ever been replaced?
Worn bushings will send your Vette sideways when you floor it if they are worn. PG.
Old Aug 21, 2009 | 09:48 AM
wtbrs123's Avatar
wtbrs123
Thats not my problem, what I want to fix is the slack in my steering wheel it is a little sloppy. It doen't dart or wander, I have about a 1/8 to a 1/4 of a turn slack in my wheel.
wtbrs123
Old Aug 21, 2009 | 10:00 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
wtbrs123
While your in there, take a look at your rag joint. they can get pretty thin and flexy over the 30 or so years.
When I got my car, the rag joint (Steering Coupler) was so worn, the metal in the couple assembly would move from one side all the way to the other.
Old Aug 21, 2009 | 10:23 AM
Fishndude's Avatar
Fishndude
I currently have the exact same problem.. I took it in for an alighnment and it didnt change a anything.. It was real scary when I had some play in the wheel but I replaced my control valve and pitman arm, which fixed the play in the wheel but it still wonders bad..
I wonder if thats my problem too.. When I launch my car from a standstill, sometimes it will veer hard to the left, like my front tires just came off the ground..
Old Aug 22, 2009 | 06:58 PM
switzerhenry's Avatar
switzerhenry
I Bought a vbp anti bump steer kit and am going to put it in.. I know they will give directions to do it but I like to be prepaired.. Can any one enlighten me with how to do it and maybe a couple of pics of a car with them on it?? Thanks for all the help guys..
Old Aug 22, 2009 | 07:12 PM
falconview's Avatar
falconview
has the car been sitting for a while, and how is your steering return after you turn a regular corner? if you have an issue with the return check the little u joints on the steering shaft, and they can also cause slack in the wheel if they are worn. The could be ceased this would cause a steering return issue and possible wander
Old Aug 22, 2009 | 11:04 PM
switzerhenry
Ya im sure it sat but I replaced everything in the front end and it still darts right after going over a bump.. Wanders a bit too. I am now moving on to replace all the bushings in the rear also.. that means everything in the car is new Hope it fixes the problem or its a waste of alot of money...
Old Aug 28, 2009 | 10:34 AM
switzerhenry
Well put whole new poly front end in, even a new rag joint everything is tight.. Still wanders and veeres to the right... When I really tromp on it, it wants to go right really hard and is all over the place... I am moving on to the rear I am crossing my fingers..
Old Aug 28, 2009 | 11:40 AM
wtbrs123's Avatar
wtbrs123
I had a little of that going on, what I did was I got a good vette guy to do a aligement he spent a lot time on the rear, he changed out all of the old shims with new ones. he did a lot of road testing and adjusting I don't recall the settings. I'll look on my paper work if I find something I'll pass it on. In my case the rear axel was the problem.
wtbrs123
Old Aug 28, 2009 | 11:55 AM
switzerhenry
wtbrs123
What was your rear axle doing? I got a itching feeling mine is in the rear too...
Old Aug 28, 2009 | 12:03 PM
Fishndude's Avatar
Fishndude
Me to, just havent gotten around to tearing it apart yet because I might have to install offset trailing arms due to my new tires so there is no sense in replacing just the bushings at this time.
Old Aug 28, 2009 | 12:06 PM
wtbrs123's Avatar
wtbrs123
It was doing that wandering thing kinda drift from one side to the other. It appears that time consuming aligment did the trick.
wtbrs123
Old Aug 28, 2009 | 01:19 PM
  #33
wiguy's Avatar
wiguy
Read Jim Shea's paper on adjusting the steering gear. You have to be careful , e.g. making sure it's centered before tightening the screw, with it or it will lock up. Also make sure it has grease in it before your start.
Old Aug 28, 2009 | 03:43 PM
  #34
wtbrs123's Avatar
wtbrs123
Just read your reply you mention to make sure there is greese in the steering gear box.
Question how do you check the grease level and where do you fill the box and what type grease?
wtbrs123
Old Aug 31, 2009 | 10:43 AM
  #35
switzerhenry
ok Everything is new and tight... Goes down the road straight.. Here is the only issue I have now.. I get over 60mph and the steering feels like it has an inch of play in it... ??? Any ideas???
Old Aug 31, 2009 | 11:38 AM
  #36
Fishndude's Avatar
Fishndude
Mine ended up being the CV/pitman arm connection.. The hole in the pitman arms had some slop in it so I just replaced both of them and it cured my play....
Did you find out exactly where the problem was coming from on the rear?
Old Aug 31, 2009 | 11:44 AM
  #37
switzerhenry
Trailing arm bushings were quite worn and so where the stabalizer bars on the bottom of the trailing arms...I still haven't put in my anti bump steering kit yet but am going to do so tonight.. I hear it will make a huge difference..
To Wandering c3 Vette
Old Aug 31, 2009 | 02:06 PM
  #38
Project80's Avatar
Project80
Originally Posted by RobbSalzmann
Be very careful adjusting the nut on the steering gearbox. Done improperly the gearbox can easily become damaged. This is one of two adjustments on the gearbox. In my experience, this has never solved the bumpsteer and tramlining conditions you are describing.
Given fresh ball joints, a arm bushes, and tie rod ends, generally those conditions are addressed most effectively by (in order of effectiveness):
  • changing to different tires (usually a bit narrower, not always)
  • increasing the toe-in
  • increasing the camber
Do you have a preferred size and brand that you have found preforms well?
Old Aug 31, 2009 | 04:53 PM
  #39
switzerhenry
I got my Vette out another mechanic and he noticed the valve on the centerlink has a bit of play in it.. It is a new valve and I don't know if there is suppossed to be a touch of play in it or not.. Does anyone know how much play should be in the valve conected to the pitman arm?
Old Aug 31, 2009 | 05:57 PM
  #40
RagTop69's Avatar
RagTop69
Originally Posted by CCrane72
Did you replace your shocks? I had darting problems with my big block until I got new ones.
The other thing I had to do was tighten the steering column at the steering box because it was too loose. You could move the steering wheel and not the wheels.
cc
+1 on the shock replacement. My BB was absolutely scary in freeway speed turns. It would wander. I replaced the shocks with KYB Gas-A-Justs and the problem went away.
