"popping" at WOT
Old 08-20-2009, 01:39 PM
taylorsk8
taylorsk8's Avatar
Default "popping" at WOT
Can anyone tell me the cause of a popping sound at WOT. Seems to always be when the engine warms up, but when it is cold I don't really ever punch it so I don't know. I have a Edelbrock 1406 w electric choke. The choke does turn off all the way when warm. I have also noticed the idle is a bit high even though the throttle is back as far as the carb will allow and frequently idles high when warm. Any help is greatly appreciated since I am new to tuning carbs.
T
Old 08-20-2009, 01:45 PM
gerry72
gerry72's Avatar
Your timing is probably too far advanced for your conditions.
Old 08-20-2009, 03:34 PM
LFZ
LFZ's Avatar
detonation man.....get that taken care of quick.
Old 08-20-2009, 03:47 PM
RobbSalzmann
Support Corvetteforum!
RobbSalzmann's Avatar
St. Jude Donor '12
If its a popping under the hood, and the idle is too fast, most likely timing too far advanced on the dist.
if is popping/cracking sound out of the tail pipes at WOT, then you are lean surging and may need to jet up the primaries/secondaries.
What does the exhaust smell like at idle? if you have the curb idle screw all the way out and it smells a bit rich, check that the secondary butterflies are closing enough, some carbs have an screw that will hold them slightly open.
Old 08-20-2009, 09:09 PM
gve
gve's Avatar
A worn cam lobe can cause it to pop thru the carb at WOT
Old 08-20-2009, 10:01 PM
Kid Vette
Kid Vette's Avatar
Old 08-21-2009, 10:55 AM
TJP440
TJP440's Avatar
T
Your high idle may be the clue, as in vacuum leak. You did'nt say whether it's popping out the carb or exhaust.
A worn cam lobe would be popping irregardless of engine temp. More info and we may be able to help
Old 08-21-2009, 11:33 PM
TimAT
TimAT's Avatar
Before HEI, points bouncing will cause it to pop too.
Old 08-26-2009, 10:09 AM
taylorsk8
taylorsk8's Avatar
To clearify, the popping is out the exhaust. I will do some checking with the information given.
T
Old 08-26-2009, 10:44 AM
Jims66
Jims66's Avatar
T
Points, timing, bad plug wire, cam lobe, coil, fuel quality, jets too small (lean condition). JMO
Old 08-26-2009, 03:32 PM
larrywalk
larrywalk's Avatar
Add tired valve springs to the list.
Old 08-26-2009, 07:08 PM
gingerbreadman1977
gingerbreadman1977's Avatar
how did you go taylor? was it timing. that would have been my guess. dizzy prob spun about 10 degrees from hard launches. when it advances more then 10 you will get popping through the exhaust from start up and thats when you know you did a real good job laying rubber.
To "popping" at WOT
Quick Reply: "popping" at WOT
