Anyone know the flow rate (gph) for the stock fuel pump for a '79? It appears the same pump was used 77-81, so if any one has a flow rate for those years, I'd appreciate it.
I'm looking to use a stock fuel pump to feed a ZZ4 since the pump that came with the turn key package does not have a port to run the return line to the gas tank, and I'm trying to avoid re-engineering the fuel system plumbing.
