Quick hydroboost question
Old Aug 21, 2009 | 03:18 PM
BB72's Avatar
BB72
Default Quick hydroboost question
I'm ordering my fittings and the only diagram I have is using a jeep steering box, not the same fittings?!?! Anyhow, what are the fitting sizes for the Corvette ps control valve. I'm guessing they are inverted flare. Thanks
Rob
Old Aug 21, 2009 | 06:18 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Rob,
PM me your email and I'll send you a parts list.
Old Aug 21, 2009 | 07:29 PM
BB72's Avatar
BB72
Originally Posted by CA-Legal-Vette
Rob,
Thanks... rasz1966@hotmail.com
Old Aug 21, 2009 | 08:12 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Rob,
Could you post it here? I'm interested in this mod as well.
Old Aug 21, 2009 | 08:27 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Hey Rob,
Hope this helps: this image shows the jeep box too and I found out the fitting sizes are same on my Steeroids r&p power assisted unit. I emailed the steeroids dudes and they replied with the hi-lo press sizes for their pwr assist unit. Same as jeep.
Ordered my stuff from Summit and checked on arrival. The fittings matched. The hose I bought in a box of 72", IIRC.
Hope this parts list is a match to other contributions. Good Luck.
Old Aug 21, 2009 | 08:33 PM
Dustup7T2's Avatar
Dustup7T2
Rob,
In my haste, I don't think I helped. After rereading your post, I see you need the fittings for the Corvette ram. Sorry about that.
Maybe the diagram can help someone else if they're switching pieces.
My bad.
Old Aug 21, 2009 | 09:19 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
If you need the impossible to find 6AN to 7/16"-24 inverted flare, I have three.
$15.00 each plus shipping
Old Aug 22, 2009 | 09:18 AM
RobRace10's Avatar
RobRace10
Originally Posted by Dustup7T2
Hey Rob,
There is an error in this drawing. The line from the hydroboost out to the Jeep steering box in is about 10-1/2" to 11" not 35". The 35" length would be correct from a Hyrdrobost to a factory steering control valve.
Old Aug 22, 2009 | 09:31 AM
RobbSalzmann
St. Jude Donor '12
Rob,
My bad.
No worries, I appreciate the thought
Old Aug 22, 2009 | 03:29 PM
BB72's Avatar
BB72
Ok...is the fittings on the jeep box the same as the top of the ps control valve?
Old Aug 22, 2009 | 03:33 PM
BB72's Avatar
BB72
[/QUOTE]
Good picture Rob, you wouldn't get a box fit like that with side mounts on a BB. I had to clearance for the stock box.
Old Aug 22, 2009 | 05:52 PM
Jim Shea's Avatar
Jim Shea
The ports in the control valve are not the same as the ports in the Jeep box. The ports in the control valve are as follows:
The large port (nearest the stud) is a female 45 degree flare with 5/8-18 UNF threads. This port is the low pressure return to the pump.
The smaller port (nearest the end cap) is a female 45 degree flare with 7/16-24 NS threads. With Hydraboost this would be the high pressure line coming from the Hydraboost unit. With conventional power steering it is the port that connects the high pressure line to the pump discharge. This is a non-standard thread. You better purchase one of the 6AN adapters from NMsharkracer while he still has one.
One last thought: The high pressure hose coming from the Hydraboost to the control valve will find the control valve actually moving side to side as you make right and left hand turns. Check the motion of the valve and the hose. Make sure that the motion isn't causing the hose to chafe against any sharp edges.
Jim
Old Aug 23, 2009 | 01:41 AM
BB72's Avatar
BB72
Thanks Jim, I will get one of those fittings, they are rarer then hens teeth by the looks of it.
Old Aug 23, 2009 | 08:34 AM
MN80Vette's Avatar
MN80Vette
I got all the fittings I needed for my HB conversion this spring from HydraTech Braking Systems. They have angled fittings too for tight fits and aesthetics too.
Old Aug 23, 2009 | 03:49 PM
Kfmorgan's Avatar
Kfmorgan
Just some info about this fitting; after searching around, I found this fitting available at JEGS. In stock.
Jegs part # 799-697100 Garrett Turbo Oil Inlet
7/16-24 inverted flare to 6AN male flare
$13.99
This is the fitting you need on the steering valve, to accept the high pressure line from the hydroboost unit.
Old Aug 23, 2009 | 04:55 PM
BB72's Avatar
BB72
I just went through Jegs and it's the only place that I've found that lists everything you need. Here's a few hard one to find
High pressure control valve fitting
http://www.jegs.com/i/Russell/799/697100/10002/-1
Hydroboost fitting and for my after market PS pump
http://www.jegs.com/i/Russell/799/648060/10002/-1
Hydroboost Fitting
http://www.jegs.com/i/Russell/799/648080/10002/-1
The ps control valve return fitting
http://www.jegs.com/i/JEGS/555/105541/10002/-1
I think the return line fitting from the hydroboost is 5/16-24
http://cgi.ebay.com/ebaymotors/hydro...Q5fCarQ5fParts
Old Aug 24, 2009 | 04:52 PM
CA-Legal-Vette
Originally Posted by BB72
Sorry guy. Missed your reply last week. I'll forward the one I have when I get home today.
Old Aug 24, 2009 | 08:38 PM
BB72's Avatar
BB72
No problem Mr Burns.
To Quick hydroboost question
