Pre-Oiler use
Old Aug 21, 2009 | 06:10 PM
AWilson's Avatar
AWilson
Default Pre-Oiler use
I hope I am doing something wrong and it is not the engine. I bought a pre-oiler and it did not come with instructions. I figured I would try to use this thing even though I am not ready to start the newly rebuild engine yet. So I put it in and hooked up my drill to it. Running clockwise oil only comes out of only one rocker arm. One of the #8 rods to be specific. I know that I need to make sure it comes out of all of them before starting the engine. Any thoughts? Maybe oil isn't supposed to come out of them all, all the time. Do I have to rotate the crankshaft in order to see oil through each one?
Also, I do not have the oil pressure gauge hooked up. Oil IS running out of that line too. Do I need to hook it up so that I can build pressure to force oil through everywhere else?
I only ran it maybe 10 seconds as I was afraid I would hurt something if I did it wrong.
Maybe it is supposed to go counter clockwise?
Any guidance is appreciated.
Old Aug 21, 2009 | 06:21 PM
SteveG75's Avatar
SteveG75
1) Clockwise is correct.
2) It takes a lot longer than 10 sec to pre-oil. Figure 2 minutes or more. Use a heavy duty drill.
3) Make sure you have a tool with the part that replicates the bottom of the distributor. That ensures that oil gets to both lifter galleries (pic below).
4) Turn crank in 90 degree increments while pre-oiling. At least two full turns. This will ensure that the lifters do not block the gallery and that oil gets up all the pushrods.
Old Aug 21, 2009 | 06:28 PM
Duke94's Avatar
Duke94
Not much can go wrong, you just didn't run it long enough. Do you have the OP gauge connected up? If not, connect it then run the oiler until pressure comes up. You can't run the pump to long, but you may burn out you drill motor if it's not up to the task.
Gary
...Roger...'s Avatar
...Roger...
and get a good grip on it. I smoked my HD craftsman on the last one I primed.
Old Aug 21, 2009 | 06:57 PM
billla's Avatar
billla
St. Jude Donor '14
You're doing fine If you're turning it backwards, you'll hear the bubbles blowing in the sump
with everything above - including burning out a good drill ;-)
Old Aug 21, 2009 | 08:01 PM
RunningMan373's Avatar
RunningMan373
Maks sure your drill is tight on it, there's quite a bit of back pressure.
Old Aug 21, 2009 | 08:33 PM
AWilson's Avatar
AWilson
Ok, I ran it longer and here are the results:
No oil pressure readings at all but I know oil is flowing to the gauge. maybe it is broken.
Driver side all push oil out satisfactorily, at least I think they are. Not running like a fountain but flowing.
Passenger side all are pushing oil but very, very, slowly. Almost can't see it. But I did fill the rockers enough that almost all of them overflowed. So maybe I am good to go?
Can't keep working on it tonight but tomorrow I will turn the crankshaft and see if it improves on that side.
Old Aug 21, 2009 | 08:41 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Yeah, if you have oil oozing from the pushrods, it's pressurizing the oil galleys ok. IIRC, the mains get oil first then the upper part of the motor next so you should be fine.
Maybe the gauge is kaput? Make sure the OP line ain't kinked or otherwise clogged. All oil ports need to be closed to build press or you'll notice quick enough when the puddle on the floor starts to grow...
Old Aug 21, 2009 | 08:48 PM
Duke94's Avatar
Duke94
It's amazing how much power it takes to run the oil pump.
Gary
Old Aug 23, 2009 | 10:52 PM
7t3shark's Avatar
7t3shark
Yeah and how much kick the drill gives you when the pump builds pressure. Want to make sure you're holding on tite.
Old Aug 23, 2009 | 10:57 PM
AWilson's Avatar
AWilson
I ordered a new oil pressure gauge. I'll let you know what happens. I guess that will be next week end. Thanks guys!
Old Aug 24, 2009 | 12:48 AM
HABIT's Avatar
HABIT
I experienced the same problem with a recent 406 build and a cheap Auto-Zone primer tool.
The solution I came up with was wraping a couple layers of electrical tape (trimmed up of course) around the lips on the cylinder closest to the pump. This provided a better seal and kept the pressure up and allowed the oil to pump through all lifters and pushrods . . .
I can throw up a couple pics if needed.
Just call me BUBBA . . .
HABIT
Old Aug 24, 2009 | 09:36 AM
jackson's Avatar
jackson
Do you have the primer tool that has the bosses at bottom to mimic those on a distributor? (like steveG says in tip3) ... bosses OD slightly larger than dist gear ... without those bosses there's a large upstream volume loss ... many of the cheaper primer tools are little more than a screwdriver shaft with no bosses.
OE GM sbc First oils lifter bores (i.e. lifters' waists) ... then cam ... then mains ... then rods. There's a hole in lifter waistband ... oil fills lifter internals & some comes out of lifters' tops & travels up pushrods' ID to rockers.
Some aftermarket sbc blocks are designed to first oil mains with "priority main oiling".
Old Aug 24, 2009 | 08:59 PM
AWilson's Avatar
AWilson
Here is the one I bought: It is a Proform 66896 fits Chevy V8
Old Aug 24, 2009 | 09:07 PM
...Roger...
I just use an old distributor without the gear.
Old Aug 24, 2009 | 09:19 PM
AWilson's Avatar
AWilson
Thats what a lot of people say and it makes sense, same as a trans input shaft for clutch alignment. But I have neither.
Old Aug 24, 2009 | 09:28 PM
billla's Avatar
billla
St. Jude Donor '14
That's the right tool. Plug the oil pressure line with a hex plug and then prime and turn the engine over in 90 degree increments. Note that this needs to be done right before starting, not well in advance.
Is everything working out at this point?
Old Aug 24, 2009 | 10:40 PM
AWilson's Avatar
AWilson
Everything IS working out so far. Just a myriad of small questions as I approach that first start. But I think I have most answered now. I wish I had a couple days solid to work on it.
Instead of plugging the oil pressure line, isn't hooking up the gauge the same? I planned on doing that for engine monitoring anyway.
I am using the Vizard method of setting static timing. If there is a better reference? Please advise otherwise I will go with that for positioning the distributor properly.
I plan to re prime just before starting. I was just curious how this thing works.
To Pre-Oiler use
