Differential fill plug ---help please
Old Aug 22, 2009 | 12:28 PM
Lotus76's Avatar
Lotus76
Default Differential fill plug ---help please
I am looking for suggestions for removing my differential fill plug.
For anyone that has done this you know how tight the space is to work. I can't get a wrench on it. I have removed this square plug in the past with a 12 point 5/8" socket.
Not this time! the corners of the square are rounded enough that I cant get enough torque on it before it slips off. This time its really really tight.
I also tried a crescent wrench from the over the top and used a ratchet extension (in the hole at the end) to turn the wrench but it wont budge (cant get much torque on it)
I used penetrating oil, vibration and heated the diff case, still no luck...
Does anyone have any creative suggestions to remove this square plug.
is there such a thing as a square socket? or a specialty tool that will work?
Sears makes a "gator grips universal socket" anyone had any luck with that?
Thanks for you help..
John
Old Aug 22, 2009 | 12:40 PM
...Roger...'s Avatar
...Roger...
I use a square socket and a 10" extension with a 1/2" drive ratchet.
Old Aug 22, 2009 | 01:30 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
A square socket is basically an 8pt socket. Try Sears. It's a 5/8".
Old Aug 22, 2009 | 02:07 PM
OMF's Avatar
OMF
I hate to tell you this.....I tried all of the above recommendations with no luck. I ended up pulling the rearend - drilling out the plug breaking some easyouts - drilling the plug out some more and eventually using a hammer and chisel to break apart the remaining plug...what a PIA
I had to get a pipe tap to chase the hole after as some damage was done to the threads.
While I was in there I looked over my rearend and discovered some badly worn parts - that led to a partial rebuild.
This all started by me changing the pinion seal......so be prepared
Old Aug 22, 2009 | 02:26 PM
GTR1999's Avatar
GTR1999
That plug is a 3/4" npt thread. Usually the 8 pt sockets work. If not hit it with a little propane and PB blaster and let it soak into the threads and try again. When I change the rear oil I just jack up the RH side on a small jack stand, slide under and remove the drain plug I installed, use the 5/8 socket and pump in fresh 80-145 Lucas.
Old Aug 22, 2009 | 03:04 PM
...Roger...
Here's what I use and I've never rounded one or failed to get one loose. Its an Apex 5620 5/8"
http://westsidedelivers.com/previewi...odtype=product
Old Aug 22, 2009 | 06:35 PM
Lotus76's Avatar
Lotus76
I got a 8 point 5/8" at sears and it worked GREAT!
I need a new fill plug for next time...corners were pretty rounded. I put some anti seize on so I can get it apart easy next time.
Thanks for the help.
John
Old Aug 22, 2009 | 08:19 PM
KapsSA's Avatar
KapsSA
Cool! never seen one of those
Old Aug 22, 2009 | 09:52 PM
7T1vette's Avatar
7T1vette
Just drop the spare tire carrier and put a 3 foot breaker bar extension on whatever you're using.
To Differential fill plug ---help please
