Chrome oil pan leak
Old Aug 28, 2009 | 05:00 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
even if you get it to seal it will look like **** very quickly.
I changed to an Aluminum Pan, atleast you can polish back to shiney anytime.
good luck..69VETT
Old Aug 28, 2009 | 05:05 PM
dburgjohn's Avatar
dburgjohn
Default over tight and sealer
I don't think I over did it. The Fel-Pro gasket I used had little sleeves in the gasket.
I did note the instructions with the gasket said sealer only at the 4 corners. Why would they not want you to seal the whole thing?
Old Aug 28, 2009 | 05:55 PM
dburgjohn's Avatar
dburgjohn
Originally Posted by MotorHead
Still not right, should be "anyone has a chrome pan that does not leak, can you tell me the brand and if you paid $30 for it"
I know it was cheap, but everything I have ever gotten from Summit was a good product.....
except this one it seems
Old Aug 28, 2009 | 06:16 PM
JimT's Avatar
JimT
I helped solve my leaky pans (oil and tranny) by using studs, and lock-tite, instead of the bolts. They never work loose.
Old Aug 28, 2009 | 07:09 PM
Oldguard 7's Avatar
Oldguard 7
I agree with the others. The chrome surface is too smooth. I had this issue with a chrome timing chain cover. The front seal at the oil pan by the cover was leaking. I also replaced the two piece oil pan gasket with the fel pro one piece gasket I switched to another cover (non chrome) and no more leaks.
Old Aug 28, 2009 | 09:47 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
eBay Chinese special, more like 50.00. No leaky
Old Aug 29, 2009 | 01:31 AM
7T1vette's Avatar
7T1vette
I didn't know that you could chrome recycled beer cans! {just kiddin', yellow72....}
chrome surfaces will seal, if you scuff them up....
Old Aug 29, 2009 | 10:44 PM
dburgjohn's Avatar
dburgjohn
Default Something old, something new
old pan + new gasket = no leak
anybody want a chrome pan? cheap!
Old Aug 30, 2009 | 12:22 AM
babbah's Avatar
babbah
Originally Posted by dburgjohn
does anyone have a chrome pan that does not leak?
Yes, everything on my engine and under carriage is chrome! I used the one piece on my chrome pan (Original Vette Pan that I had chromed) and no leaks! I used a bead of rtv on both side of the entire gasket and let it cure for a few days before I started it - It is dry as a bone...no leaks! I never sanded any chrome parts on my car for sealing. And yes chrome is a challenge to seal, especially on my 3x2 carbs!! (See July 2009 Corvette Enthusiast Magazine - Page 74-77)
Old Aug 30, 2009 | 12:54 AM
b71vette's Avatar
b71vette
Originally Posted by TimAT
The oil detection kit is an additive you pour in, run the engine and look for traces with a UV light and some color goggles. (Beer Goggles will NOT work, BTW) The light makes the additive glow and you can see exactly where the leak is coming from.
Back to the original question- chrome is so slick that most gaskets won't "bite" and will seep. Take some 180 grit sandpaper and rough up the rails on the pan- go lengthwise, don't go across. I've seen this happen on trans pans too.
Old Aug 31, 2009 | 11:05 PM
dburgjohn's Avatar
dburgjohn
Default CSI style UV dye
only thought it fixed. I watched it run for 15 min and no leak. But when I went out next day, oil on the floor on both ends of the pan. I bought a UV dye from Autozone with the UV light and glasses. It is supposed to glow so I can see where it comes out. The plan is to set all four wheels on ramps so I can move freely underneath the car.
stupid oil leaks
Old Sep 7, 2009 | 12:55 AM
dburgjohn's Avatar
dburgjohn
Default UV Dye
the leak came out the back of the valve cover, down the back of engine, over the starter, onto the transmission oil lines and towards the front of the engine where it dripped. They dye is awesome plus the yellow glasses look really cool
