overhauling 76 L82 need help
Wanted a new pan because the old one looked like it had run into a hundred big rocks. Couldn't find a new oil pan without the built in windage tray. Ended up ordering one from my local GM dealer. It appeared to be the replacement but the baffles are slightly different and the pan doesn't fit either.
Ordered a new billet thermostat housing to fit my new edelbrock intake. They sent a 45 deg. angle instead of a 15 degree.
Ordered a cast housing from my local parts store. It did't fit either. It was less than 15 deg. outlet.
I'll take it back tomorrow. I spend more time looking and returning parts than assembly.What can I do or who can I order parts from? Can anyone with a L82 help me find these parts?
The pan was discontinued by GM but the great folks at Wilcox spent a lot of their time trying to cross reference to a new #, unfortionately the baffles are at slightly different heights(1/4") on one side and the pan won't clear the windage tray. I reused the origional main bolts/studs and windage tray. The old pan fits fine.
It seems the L82 differences are thowing the suppliers for a loop.
First of all, the oil pan on the L82 is the same as the oil pan on the L48. It is also a pretty generic pan of that mid-70s, so it shouldn't be too hard to get a replacement that fits. Having said that if you do start mixing and matching parts you can encounter problems.
If you want original, I would stick with a vendor such as Paragon that carries just about any original part you might want. They specialize in the C1's, C2's and C3's so they are very knowledgeable on our cars. They are also a great resource if you have questions and best of all their prices are not outrageous as you might expect.
If you are willing to use aftermarket, which opens you up to lots of possibilities, I would shop with a company like JEG's or Summit. Both of these companies have experienced folks on their staff that can tell you exactly what components work together as they've done it thousands of times. They make their living "building" engines for customers. They're not perfect, but they have a lot more experience at outfitting engines than most vendors and auto parts stores do. Their prices are generally excellent and their shipping times are not excessive.
Sometimes we tend to get caught up in shopping around for best prices or a local store and end up paying in aggravation or having to return things that don't actually work together.
Good luck and don't give up... just try a different tact... GUSTO
