Turn Signals Blinking FAST
Old Sep 1, 2009 | 04:01 PM
VictoriaVette's Avatar
VictoriaVette
Default Turn Signals Blinking FAST
So my turn signals are blinking really fast do I need to change out the blinker in the fuse box?
Old Sep 1, 2009 | 04:10 PM
OMF's Avatar
OMF
Usually thats an indication that one of your bulbs are burned out. Check them out
Old Sep 1, 2009 | 04:11 PM
Young69Owner's Avatar
Young69Owner
The blinker module in the fuse box is for the four ways. You want the one behind the passenger's dash.
Old Sep 1, 2009 | 04:20 PM
VictoriaVette
I need the remove the passengers dash to get to it?
Old Sep 1, 2009 | 04:28 PM
Ganey's Avatar
Ganey
No, you can see the flasher. Probably a bulb, not the flasher unless you did something like 4 tail lights.
Old Sep 1, 2009 | 05:37 PM
VictoriaVette
If it was a bulb wouldn't the signal not work on one side? I thought that when I had a blown bulb in my Nova it would not blink on that side and the light on the dash just lite up.
Old Sep 1, 2009 | 05:53 PM
pws69's Avatar
pws69
Try looking at the bulbs with the signals on!
Old Sep 1, 2009 | 06:33 PM
VictoriaVette
I did look at the bulbs with the signals on they blink really FAST.
Old Sep 1, 2009 | 07:04 PM
7T1vette's Avatar
7T1vette
All of them? .....or just the ones that are supposed to flash.
Old Sep 1, 2009 | 07:18 PM
VictoriaVette
Only the ones that are supposed to!
Old Sep 1, 2009 | 07:24 PM
Peterbuilt's Avatar
Peterbuilt
Did you try to switch out the 4 way flasher with the turn signal one? PG.
Old Sep 1, 2009 | 07:29 PM
VictoriaVette
No but if I can I will and see what happens.
Old Sep 2, 2009 | 12:08 AM
7T1vette's Avatar
7T1vette
If you swap the emergency flasher for the turn signal flasher and nothing changes on either circuit, it's definitely not the flashers. For the bulbs to be working OK and the flasher to operate too fast, there must be some additional current draw on the turn signal line when it is activated. This didn't begin right after your changed some bulbs, did it? If so, make sure you installed the correct bulb number. Otherwise, check for some [partial] shorts in the turn signal circuit. Maybe a chaffed wire somewhere....
To Turn Signals Blinking FAST
