Eliminating AC compressor
Old Sep 3, 2009 | 02:55 PM
wiguy's Avatar
wiguy
Default Eliminating AC compressor
This may have been talked about before, but I couldn't find a thread on it. Freon leaks and I don't need the AC, can I just remove the compressor, cap the hoses and tuck them out of the way, or do I need to replace the compressor with an idler to keep belt?
Old Sep 3, 2009 | 03:17 PM
Ganey's Avatar
Ganey
Yes & no need "to replace the compressor with an idler".
Old Sep 3, 2009 | 03:25 PM
Vegas69's Avatar
Vegas69
Check out http://acdelete.com/ if you are going to remove your compressor and want it to look clean and tidy.
Old Sep 3, 2009 | 04:24 PM
redman76's Avatar
redman76
St. Jude Donor '09
I'm doing the same thing for now; someday I may replace compressor. The acdelete looks great, but for $180 I could just fix the AC. Compressor is off and hoses are dangling . . . I'm interested to see who else has removed and how they delt with it.
Old Sep 3, 2009 | 04:41 PM
7T1vette's Avatar
7T1vette
If there is another accessory on the same belt with the A/C, you will need to get a shorter belt after removing the compressor. My advice would be to leave the A/C unit in place, but remove the fuse for the compressor clutch (or just disconnect the clutch power connector). The only disadvantage to leaving it in place is the extra weight. If you leave it in place and decide to sell it, it should sell better with all the A/C system in place (even if it is not charged).
Old Sep 3, 2009 | 06:52 PM
Paul L's Avatar
Paul L
Just drop the belt. A lot of value in the original system. Leave it there.
Old Sep 3, 2009 | 07:55 PM
markids77's Avatar
markids77
Or post the system on the for sale side. I need a set up here in Georgia!
To Eliminating AC compressor
