rear axle codes
Old Sep 8, 2009 | 04:53 PM
mike62202's Avatar
mike62202
Default rear axle codes
have a numbers matching 71 vette,454,m21 munci my question is the rear axle codes the numbers read as c j11 28 62 w&w,i have a pic but dont know how to post it,
Old Sep 8, 2009 | 08:50 PM
CCrane65's Avatar
CCrane65
1971 Rear axle codes are as follows:
AA 3.55:1
AB 3.70:1
AC 4.11:1
AD 4.56:1
AW 3.08:1
AX 3.36:1
LR 3.36:1
Axle plant codes:
B=Buffalo, D=Dana, E=Eaton, G=Chevrolet Gear &Axle, K=McKinnon Industries, W=Warren Motive
Positraction Sources:
E=Eaton, W=Warren Gear, D=Dana
From the 1970-72 NCRS Technical Information Manual & Judging Guide 4th Edition:
"For 1971 and 1972 the stamping began with two letters for the ratio code, a letter for the axle plant, one to three numbers for the julian day of the year, a letter for the Positraction source, and a number for the shift".
Based upon that, I'm not really sure what you have. Maybe you misread some of the characters?
To post a picture open a free account on an internet file server such as Photobucket, upload the picture, then go to the uploaded picture and when you hover over it with your mouse a menu will display underneath it.
Select the IMG line and do a control c to place a copy in the paste buffer then go back to your CF thread, edit your post and select a location in the edit box and do a control v to paste the picture.
You can use right click and copy and right click and paste in place of the control c and control v.
cc
Old Sep 9, 2009 | 08:26 AM
mike62202's Avatar
mike62202
found a way to post the pic in my profile pic,click on my profile and you should see the pic,yailkes to a goy here in ga and he said that it was a special ordered 411 rear
Old Sep 9, 2009 | 10:02 AM
CCrane65's Avatar
CCrane65
You can get a pretty close idea of the ratio by marking the driveshaft with a chalk line and then put one on the tire then turn the wheel and count the revolutions of each. If it is a 4.11:1 you should see the driveshaft turn a little over 4 times for every tire revolution.
As far as the stamp, if you have the tank sticker it should have a notation on it if the car was ordered with a special differential.
cc
Old Sep 15, 2009 | 02:11 PM
airtime's Avatar
airtime
4.11 = 3500 rpm at 70 mph with a 265-60-r15 tire in 4th gear
To rear axle codes
