Engine block Serial Number
Old Sep 11, 2009 | 06:27 PM
iceref63's Avatar
iceref63
Default Engine block Serial Number
Is there any other place on the engin block which holds the serial number other than just below the passenger side cylinder head? It looks like mine has been milled down.
Old Sep 12, 2009 | 02:47 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
That pad is the only place it's going to be. If the engine was milled, then there's no way to verify it. It's a great touch, when they restamp after milling. But very rare.
Old Sep 12, 2009 | 08:17 PM
Alan 71's Avatar
Alan 71
Hi I,
I've heard discussions about a liquid material (acid?) that can be put on the decked block surface that sometimes makes the original stamped characters legible. I think it has something to do with the way the smash of the stamp affects the iron molecules below what was the visible stamp. $$$???
How important is it?
Regards,
Alan
Old Sep 12, 2009 | 10:26 PM
7T1vette's Avatar
7T1vette
It's called a 'nital etch' and it uses nitric acid [I think]. The area under the stampings is work-hardened by the stamping process. If the block isn't milled so much that it completely eliminates that impression, that process may reveal the original stamping image. If it does, take a digital photo of it...it won't last long.
To Engine block Serial Number
