71 Chassis restoration question
Old Sep 12, 2009 | 05:35 PM
pbergmann's Avatar
pbergmann
Default 71 Chassis restoration question
I am in process of doing a body off resto on a small block coupe.
I would like some opinions on the difficulty level of rebuilding the following parts myself or spend the $$ and getting them rebuilt or buying rebuilt/new parts. Please list from 1 to 5 (5 being most difficult) based on your experiances. All items worked and did not leak prior to resto start.
Power steering pump
Power steering control valve
Power steering cylinder
Steering box
My my goal right now is NCRS top flight... maybe higher down the road. The car has limited upside so I can't be throwing money at things that I may be able to do myself. The car is a one owner 60k mile car 90% original but well worn.
Thanks in advance!
Pete
Old Sep 12, 2009 | 05:54 PM
Duke94's Avatar
Duke94
The steering control valve and steering box are the most complex, but all are do-able. There is a ton of info on this Forum and the internet on rebuilding all of these. I rebuilt them all myself on my 71'.
Gary
Old Sep 12, 2009 | 07:23 PM
Artsvette73's Avatar
Artsvette73
The old saying is "if it aint broke" I would clean the items up and be done with it. The steering box I would take it apart and clean out all the old grease. Don't be intimadated by it just read Garys GTR1999 papers
Old Sep 12, 2009 | 07:34 PM
Alan 71's Avatar
Alan 71
Hi Pete,
Since I have a 71 sb coupe too, I'd love to see some pictures of what you're working on!!!
Regards,
Alan
Old Sep 12, 2009 | 10:14 PM
boat196's Avatar
boat196
I had my parts professionally rebuilt, I'm currently in a body off restoration. it makes the restoration progress faster.Their sure is alot to do and keep track of.
Bob
Old Sep 12, 2009 | 10:33 PM
7T1vette's Avatar
7T1vette
You can easily rebuild the steering control valve and cylinder for 'chump change'. The rebuild stuff is very inexpensive. If the steering box was working properly and did not have any 'slop' in the steering action, you can likely just refill the box with new lube and clean it up good. Some boxes get painted; some are bare cast iron. If you want to get 'Top Flight' rating it will have to be right and I would recommend that you have a professional rebuild it and refinish it. The most realistic look for a bare cast iron box would be to shoot the empty casting with Seymour 'Cast-Blast' exhaust manifold paint and then bake it to a natural cast iron finish that won't rust!
If your power steering pump was working fine and had no leaks, clean it up and repaint it. Rebuilding should be done by a pro, but only if it really needs it.
Old Sep 13, 2009 | 09:09 AM
pbergmann's Avatar
pbergmann
Thanks for the replys. Its that old while I'm there syndrome...it never seems to stop. At least now I'm down to the chassis so someday the reassembly will start.
Old Sep 13, 2009 | 10:40 AM
72LS1Vette's Avatar
72LS1Vette
with others in that if those parts aren't leaking just clean them up and put them back on. Changing the grease in the steering box is a good idea also.
If you have to rebuild the control valve, there are 2 rebuild kits available. One is the inexpensive seal kit for the fluid side and the other is a somewhat more expensive kit for the adapter side. If the ball end of the stud is worn or there are grooves in the sleeve then the adapter side should be rebuilt also. IIRC, the 2 kits cost $50.00 or so total. A rebuilt valve costs more like $170.00 so rebuilding was my first choice.
Rick B.
To 71 Chassis restoration question
