tested hot engine without thermostat
Old Sep 13, 2009 | 02:53 PM
AWilson's Avatar
AWilson
Default tested hot engine without thermostat
Since I have had my engine broke in (1 week) it has been running hot. I am still learning about timing etc. but I believe it is pretty close right now. In the meantime I thought I would pull the thermostat and run the engine without it to see what happens. It worked. I think it will run all day at 195-200 degrees. which is basically straight up on the gauge. I believe the thermostat is a 180 but I never tested it. My assumption is that I have a faulty thermostat. What do you guys think.
Old Sep 13, 2009 | 03:29 PM
'75's Avatar
'75
That sounds reasonable. A new thermostat may be the answer.
Old Sep 13, 2009 | 05:05 PM
Alan 71's Avatar
Alan 71
Hi AW,
Perhaps you can 'cook' it in a pan of water on the stove to see if it opens as the water heats up.
Regards,
Alan
Old Sep 13, 2009 | 05:16 PM
CFD E59's Avatar
CFD E59
Did you put a high flow water pump on, if so I suggest a high flow thermostat. Good luck
Old Sep 13, 2009 | 05:38 PM
OzzyTom's Avatar
OzzyTom
Was a new temp sender unit installed on the new motor?
Are you sure motor is actualy running hot? Use an infrared temp gun to check independantly of gauge in car. It might simply be the wrong temp sender unit for your gauge.
cheers
Old Sep 13, 2009 | 06:30 PM
Ganey's Avatar
Ganey
Originally Posted by AWilson
Since I have had my engine broke in (1 week) it has been running hot. ...
Sounds like it. Anyway a thermostat needs to be replaced from time to time before it fails closed.
Old Sep 13, 2009 | 08:45 PM
7T1vette's Avatar
7T1vette
If you have NO thermostat in the system and the engine heats to 190-200F, why do you think it would run cooler if it had a 180F thermostat 'blocking' the flow of water through the system? The thermostat will only stabilize the water temp at its designed temperature [180F in this case] if the engine with no thermostat runs at cooler than 180F. You need to figure out why your system wants to run so hot with no stat in the system.
Old Sep 13, 2009 | 09:01 PM
AWilson's Avatar
AWilson
Because the 180F unit would over heat the engine, the temps just keep going and I have to shut down. so I thought 160 might be better. I did check the 180 and it definitely was all open by 180. I think my answer is because I don't have the system pressurized. It is open to the atmosphere because i have the body off. This is what the guy at Napa told me. I am going to hook up the expansion tank tomorrow and see what happens. If so, then I didn't realize how important it is to pressurize the system.
Old Sep 13, 2009 | 09:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
be sure to drill a 1/8" hole in the thermostat so that you have a minimal amount of water flow and no air will get trapped in the system
Old Sep 13, 2009 | 09:20 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Sounds like your cooling system is maxed. Did you add a bunch of HP with the new engine? HP = heat. If so, it may be time for a bigger radiator and/or a high flow pump.
Get your engine dialed in first. If she's too lean and/or the ignition is retarded and/or there's vacuum leaking, she can run hot.
If it's still running hot, you may have to invest some pesos in a radiator and pump.
Good luck!
Old Sep 14, 2009 | 02:09 AM
Z-man's Avatar
Z-man
195-200 is perfect for a SB Chevy engine, which is also why the engineers designed the gauge to be straight up at normal temperature. Pressurizing it may help a bit, and will prevent the coolant from boiling.
If I were you, I'd move on to something else...
Old Sep 14, 2009 | 08:12 AM
Ganey's Avatar
Ganey
The thermostat regulates the low temp., not the highest. For example if you ran a 160 the only time you would expect it to run 160 is in the winter & 160 would be too low.
If it was running 210 in summer, it would run 210 w/ a 160 or 180 thermostat.
No pressure evaps. the water.
Old Sep 14, 2009 | 09:45 AM
Mike Ward's Avatar
Mike Ward
Say what? Can you explain please? Pressurizing the system makes no difference in operating temp, only the point at which the coolant boils.
Old Sep 14, 2009 | 10:38 AM
pewter-FRC's Avatar
pewter-FRC
you say you have the body off?? so i assume there is no shroud? just a fan on the water pump? no air is being drawn thru the rad with this setup. i would def run the 160 thermostat, and put youre house fan in front of the rad when you run it
Old Sep 14, 2009 | 11:34 AM
billla's Avatar
billla
St. Jude Donor '14
It's a quick test for the thermostat, I'd start there. Also agree that with no shroud airflow could be an issue.
Several of these points have been made, but as noted the thermostat does not regulate the temperature of the engine - if it runs at 195, then it runs at 195 and the thermostat has nothing to do with it. Once it's open, the temp is up to the engine
I wonder a bit about timing as well...possibly too advanced from the start/break-in?
Old Sep 14, 2009 | 01:26 PM
7T1vette's Avatar
7T1vette
The thermostat does regulate the temperature of the cooling system, as long as the system will stabilize at a lower temp than the rating of the stat when there is no stat in the system. It's amazing how many folks have no concept of what the thermostat does or how it operates....
P.S. The SB engine was designed to operate at 180F; and its cooling system is designed to keep the engine cooler than 180F {otherwise, it couldn't function properly with a 180F stat}. The only reason it [now] runs at 195F is because that's the temp rating of the stock thermostat.
Old Sep 14, 2009 | 01:30 PM
noonie's Avatar
noonie
And they have no intention of learning either...
To tested hot engine without thermostat
Old Sep 14, 2009 | 01:32 PM
Mike Ward's Avatar
Mike Ward
It's much more fun pretending that the cooling system is full of black magic voodoo.
Old Sep 14, 2009 | 01:49 PM
AWilson's Avatar
AWilson
That's what I thought and told him. He said that the pressurized fluid is more efficient at removing heat. I will see tonight because I will have it pressurized.
Old Sep 14, 2009 | 01:51 PM
AWilson's Avatar
AWilson
No, no. The shroud is on and on right just as it would be in the car. No leaks through the shroud, the gasket on the shroud is right up against the radiator.
