Battery Cable questions
Old Sep 15, 2009 | 11:22 AM
Clams Canino's Avatar
Clams Canino
Default Battery Cable questions
1968 Vert.
1. Are the cables #4 guage as I suspect?
2. Where can I get JUST the grommets for the battery box?
3. Where can I get new connectors for a top-post battery?
-W (using marine grade cables to make my own - because I have them on hand anyway)
Old Sep 15, 2009 | 11:45 AM
Donald #31176's Avatar
Donald #31176
Since your not going for NCRS correct I would use 1/0 size SGT copper cable instead of 4 gauge. Custom Battery Cable in Arizona can sell you the ends but your will need a good crimping tool to do the connections right.
http://custombatterycables.com/parts/just_parts.htm
Old Sep 15, 2009 | 11:48 AM
Clams Canino
Not just NCRS incorrect - but CHEAP I am.
I have the 4 guage stuff *on hand* including the lug ends and shrink sleeve All I need are the battery ends and grommets.
But thanks!
-W
Old Sep 15, 2009 | 03:52 PM
Alan 71's Avatar
Alan 71
Hi W,
I see the grommets listed as part of the reproduction cables in various vendor's catalogues, but not alone. Maybe Lectric Limited?
Regards,
Alan
Old Sep 15, 2009 | 05:31 PM
7T1vette's Avatar
7T1vette
Battery cables are 2 AWG....not 4 AWG. You would do best to buy welding cable as it has many more strands and the cable is much more flexible than standard production wire. The top-post terminals should be available at any auto parts store; I'm pretty sure that NAPA can get them. Most are screw-clamps to attach the cable, but it will be inside the case anyway. Or you could clamp the wire to the terminals, then solder them in and cut off/grind off the screw lugs, if you want.
Old Sep 15, 2009 | 08:02 PM
Project80's Avatar
Project80
These vendors may have what you want:
http://www.ronfrancis.com/
http://www.painlessperformance.com/
Old Sep 15, 2009 | 09:14 PM
Clams Canino
Originally Posted by Alan 71
Hi W,
Regards,
Alan
That's what I've been seeing too. Amazing.
-W
Old Sep 15, 2009 | 10:06 PM
markids77's Avatar
markids77
mcmaster.com Mcmaster Carr has all things electrical... and fastener... and...!
Old Sep 20, 2009 | 08:30 PM
Clams Canino
Thanks for the info.. I have #2AWG marine bat cable in stock here as well - So I'll use that. Looks like I'll have to search the sites mentioned.
I'm kinda surprised no one has run up against this before and therefore having the venfor and part# at thier fingertips. It sucks being a "pioneering" searcher with a dial-up.
-W
Old Oct 19, 2009 | 09:34 PM
mandingo214's Avatar
mandingo214
As I plug through the list of items from my recent '74 purchase, I noticed that there is a slight pause from when I turn the key until the starter turns. Then the starter turns, slowly at first, then regular speed until it starts.
Looking under the car, I can see where all the insulation has been burned off the positive cable, near the exhaust manifold right before it attaches to the started. Lots of corrosion there as well, though the cable is probably at least 2-3 inches from the manifold.
So I need to replace the positive cable.
My questions are:
Is it probable that the bad cable is the cause of the starter delay
or is it some other problem?
Will welding wire be able to withstand the heat from the exhaust manifold? It looks like the cable is run through the routing islets, but maybe one is missing above the starter.
Thanks.
To Battery Cable questions
