original 71 bbc rebuild thread.
differental had this : AW W 34 E 1 1500 rpm at 40 mph with 255-60-15 tires .
engine c11s110049 t0125cpj
intake 3866287 a1271
carb (replaced by second owner due to first owner getting a divorce) quadrajet 7042220 c2 em
trans had a metal tag 71 s 2308 and 71 s 399 i could not get a clear view of the serial number because of the linkage and exhaust.
trim tag in door jamb says g 16
master cylinder says 29969
2 new caliper has delco moraine 5473806 5452284 and 229-9x other one has 5473795 5473798
all i could see right now. car appears to be a survivor but will have to see how it checks out. car has a/c and has the brass radiator resorvior on the passenger front fender. factory exhaust manifolds but could not read them. car has no rot that i can see just some light surface rust on the bare metal parts. interior has 454 data plate. everything appears to work, fiber optics included.
thanks guys. i will post pics tomorrow as i learn how. this will be an on going resto and i plan to document everything as best as i can. florida car by the way.
all advise recommendations appriciated.gerald
Your Engine suffix CPJ is 1971 Corvette 454. Check vin
Differential code looks correct for 3.08 which was LS5 ratio
Trans tag looks right. Look for vin
Carb is off a 1972 Chevelle 396
Intake should be 3955287. Check it you probably read it wrong, easy to do. Date code is Jan 12 1971
trim 417 paint 989.
what do you think about changing the rearend gearing to a 3:55. would this hurt the original value?
i got a handle on a possible original front clip so it may be looking more original soooooner rather than later.
thanks for the carb info. i will have to keep an eye out for the original.
mike can u post some pics of your engine compartment for me. thanks
You sound pretty excited and pleased. Good for you!!!
It would be great to see some pictures of just what you have.
If you're thinking about returning your car to original condition you might want to document what you do with 'before', 'during', and 'after' pictures.
Now the FUN starts.
Regards,
Alan
gerald
also, i notice today that i had fuel leaking from the top of the new gas tank onto the pass rear muffle. is there anything on top of the tank to leak? i know some of the original rubber hoses were cracked and in-need of replacing and is on top of my to do list.
the above post is actually the driver side rear,my bad. this is the passenger side that i drilled out. notice the northern rust belt looking metal. this car is from the south and the rust looking stuff wipes off easily with sand paper. not sure what it is, but it is not rust/rot. just 30 plus years of crud i guess.
