Decode Engine?
Old Sep 20, 2009 | 09:59 PM
TyCor's Avatar
TyCor
Default Decode Engine?
I have owned by '77 for a few years know, and still don't know if I have a 327 or 350...Here's the story. I bought the car a few years ago on e0bay. The guy was not a vette guy, he received the car as payment for some contracting work he did. He told me he thought the car had a 327 in it. I pulled the numbers of the block, and they say that it could be either a 327 or 350. I tried to replace the starter last week and it has offset holes..which come to find out... the only starter to fit the car was one for a 1968 327. How can I tell for sure what engine I have...other than the block numbers, what other numbers can I look for and where are they located?
Old Sep 20, 2009 | 10:06 PM
Mike Ward's Avatar
Mike Ward
The casting number and date would be a good start even if there's nothing on the stamp pad.
Is the oil filler cap on the valve cover, or on the end of a tube at the front of the intake manifold?
Old Sep 20, 2009 | 11:24 PM
68blueshark's Avatar
68blueshark
Default cast code 327 - 1968
hello
The engine block cast code for a 1968 327 is 3914678, and the heads are 3917291 or 3917292.
Good luck.
Ed
Old Sep 20, 2009 | 11:44 PM
69elky's Avatar
69elky
Default 327/350?
For a quick check your casting # for your 77 should be 3970010.
To Decode Engine?
