Front clip problem
Old Sep 25, 2009 | 03:44 PM
Gerry80's Avatar
Gerry80
Default Front clip problem
I've been trying for a long time to adjust my doors (both sides) to get the front gap somewhat consistant, but kept running into problems with it being way too high in the back once I did. I started looking at the front clip and it seems it was installed (or repaired?) incorrectly.
Notice the larger gap at the bottom, it's about 1/2" too high. It seems if this was corrected it would solve a bunch of alignment problems I've been having (doors, hood). It's the same on both sides.
My question is what's the best method of fixing this? I'm thinking I need to break it from from the bonding strips and rebond. I've heard reinstalling a front clip can be a nightmare to align.
I also need a small amount of fiberglass repair on the fender. Does anyone have any suggestions for someone in the Chicago area.
Old Sep 25, 2009 | 09:21 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
your only showing the bottom corner of the door.
We need to see all the gaps, and pull that rocker off, to review the alignment.
You can tell If the fender is installed correct by following the steel bottom rocker channel (actually part of the bird cage), under the fiberglass door sill. If you follow the steel rocker, you should see the fiberglass body below the door sill,
with about 1/8" gap between them, that ends about at the door hinge,
the bottom of the front fender should follow that same line, with about 1/8" gap between the steel bird cage rocker. 69VETT
Old Sep 26, 2009 | 04:57 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
...You are only giving us a piece of the puzzle. many thigns to consider. are your door bushings tight or do you have "up & down" movement in the door when you lift it up...at the back edge..when the door is slightly opened?
Detailed photo's are needed. I for one... need to see the area where the top of the doors meet the front end. But all gaps are needed...front and back edges of the doors. And is your door in the photo that you did post..having the door skin being separated from the inner structure...it looks like the outer skin is coming away from the inner structure.
"DUB"
Old Sep 26, 2009 | 07:59 PM
Gerry80's Avatar
Gerry80
OK, here's the pictures. I took the rocker panel off and found below the door the panel is consistant with the gap, the front fender panel is again higher.
In the pictures the in front I have a 1/8" gap at the bottom and a 1/4" gap at the top. In the rear, I have a fairly consistant 1/8" gap and the high point of the door flows into the rear fender.
Old Sep 26, 2009 | 09:02 PM
69Vett's Avatar
69Vett
front fender is bonded to high. 69VETT
Old Sep 27, 2009 | 10:17 AM
Former Vendor
But I would have liked a photo of the front top edge of the door where the top hood surround/fender meet the top front edge of the door...a sraight on shot...not at an angle. This is so if I/we can tell if the area where the fender bonds to the top hood surround was altered...and may need to be separated...and lowered...or if the entire area at the front endge of the door needs to be repositioned. I/we have seen so many "BUBBA" jobs over the years...nothing surprises ...me at least.
"DUB"
Old Sep 27, 2009 | 07:38 PM
Gerry80's Avatar
Gerry80
Grandmaster, are these the shots you were requesting?
Don't know how this post ended up in the Tech section, any way to move it to general?
Old Sep 28, 2009 | 05:56 PM
Former Vendor
Thanks for the photo's. The photo is telling me that your door may need to be raised ...so the top edge of the door is flush and level with the top egde of the hood surround. The front of the door is DOWN. BUT...it also depends on the photo that you need to send that shows the area of the top hood surround where it is bonded on the firewall/cowl area by your driver side hood latch. (shoot from passenger side) And also a photo...if you can...of the area at the end of the top hood surround from the door hinge side. ...do with the door open....so I can see how much adhesive was used to bond the top of the top hood surround to the bracket that is riveted to the cowl..... at the "pointed" end of the hood surround. IF the end of the "pointed" portion of the hood surround is loose...then your door may be fine because some "BOZO" did not know what they were doing.
CAll me if you wish.
"DUB"
(704)394-5150 M-F 8:30-5:00 EST
Old Oct 2, 2009 | 03:02 PM
Gerry80's Avatar
Gerry80
I'm starting a new post in the C3 General section, where this really belongs.
To Front clip problem
