1976 L-48 Head flow
Old Sep 28, 2009 | 02:19 PM
halleyro's Avatar
halleyro
Default 1976 L-48 Head flow
I was wondering what the cfm and flow numbers for my stock heads on my l-48 are. I also want to know what the valve size is for intake and exhaust. Also i was looking for a good stock upgrade for a 383 im building. I was wondering what car models and years i might be looking for heads off of.
Old Sep 28, 2009 | 03:15 PM
7T1vette's Avatar
7T1vette
If you are going with a 'stock' steel head, you can't really use a head with more than 9.5:1 compression using today's 93 octane fuel...or you will have a spark knock (pre-ignition) problem. So, that limits your choices to the '71 & '72 LT1 heads or later L82 heads...all of which were 9.0:1 compressions. With a thin head gasket you could get that up to around 9.2:1. You could also go with 'stock' L98 heads which are 9.5:1 and much better flowing; but you would also need an intake that will fit the L98 heads (stock GM intake or aftermarket unit will fit on your engine block), as well.
Old Sep 28, 2009 | 06:17 PM
halleyro's Avatar
halleyro
what head would you use? will the heads off of 70 lt1 work or a 68 or 69?
Old Sep 28, 2009 | 06:29 PM
63Nova's Avatar
63Nova
Why build a 383 if you are just going to limit it with a stock head?
Old Sep 28, 2009 | 06:43 PM
halleyro's Avatar
halleyro
because i dont have the budget for nice heads yet
Old Sep 28, 2009 | 06:48 PM
63Nova's Avatar
63Nova
You can get a set of aluminum patriot heads for 900.00 complete.
Old Sep 29, 2009 | 01:48 AM
Solid LT1's Avatar
Solid LT1
Actually the L-48 and L-82 heads can be same casting numbers in 76 Vettes. Difference in the 2 heads is valve sizes L-48=1.94int/1.50exh L-82=2.02int/1.60exh. The bigger intake valve came with a proper combustion chamber relief cut for better flow, if it isn't done the 2.02 valves flow are shrouded and about the same as 1.94 valves but, the 1.60 exhaust valves show BIG IMPROVEMENTS over 1.50 valves. Heads were machined for guide plates and screw in rocker studs. For all the $$$ it would take to rework the L-48 heads onto L-82 heads properly, your better off going with a Brodix IK series head with it's smaller chambers to raise compression. Flow figures for 1.94 L-48 head are around 180-190CFM@0.450 lift and 130-140CFM exhaust. L-82 head 205CFM intake@0.450 and 170CFM exhaust.
Old Sep 29, 2009 | 06:27 AM
Gordonm's Avatar
Gordonm
To rework a set of decent stock heads yo uare going to be in the same price range as a new set of better heads. It does not make any sense to rework stock heads unless you are NCRS. The cost of new heads and the performance of them far outweighs redoing older heads.
Old Sep 29, 2009 | 09:04 AM
billla's Avatar
billla
St. Jude Donor '14
To answer your original question:
.100 56/57
.200 108/77
.300 157/110
.400 180/125
.500 187/133
You don't want to put any time or effort into stock, "vintage" GEN I heads; the return is small and you're really not saving any money.
I've taken heat for this before, but if this is a MILD 383 a stock set of Vortecs will feed it to 5200 RPM or so. Without more details on the build, it's not possible to say.
You need to give more information to get a useful answer to your question.
Old Sep 29, 2009 | 10:57 AM
halleyro's Avatar
halleyro
do i need a different intake if i went with a set of vortec heads? i really wanted to reuse my air gap intake
Old Sep 29, 2009 | 11:01 AM
7T1vette's Avatar
7T1vette
yes.
Old Sep 29, 2009 | 11:11 AM
gerry72's Avatar
gerry72
Originally Posted by billla
...I've taken heat for this before, but if this is a MILD 383 a stock set of Vortecs will feed it to 5200 RPM or so. Without more details on the build, it's not possible to say.
I can find no fault there. That's what Chevy did with the HT383 package. Seemed to work out fine for them.
Old Sep 30, 2009 | 10:15 AM
billla's Avatar
billla
St. Jude Donor '14
Trust me - you do not want to enter this door. There be dragons
To 1976 L-48 Head flow
