Edelbrock performer
Old Sep 30, 2009 | 10:11 AM
timbuck's Avatar
timbuck
Default Edelbrock performer
I just bought a 1981 Vette that has a quadrajet on an Edelbrock performer intake. My question is, do I have the quadrajet rebuilt or do I splurge on a new Edelbrock Performer Carb. If I go with the Edelbrock Carb, will the factory air cleaner setup still work? If any of you have made the swap, have you been happy with the Edelbrock? I appreciate your input on this.
Old Sep 30, 2009 | 10:18 AM
Roughrider's Avatar
Roughrider
I say get your Q-jet rebuilt. I had a '78 L82 I installed a Performer intake on with the original Q-jet and it ran great. No need to replace your carb unless it's physically beyond rebuilding.
Besides it's a better street carb, sticking with the Q-jet means you don't have to re-plumb the fuel lines, filter, linkages, etc. If your car has a/c, it also saves having to buy and install a different a/c solenoid on the carb to keep the idle from dropping and stalling when the a/c is engaged. That's a proprietary and expensive Edelbrock part to add. An easy thing to install but adds to the cost of the swap.
I'm not knocking the Edelbrock carburetor...it's an excellent piece and you would probably be quite happy with the swap, but you really won't gain anything beyond lightening your wallet and a nice Edelbrock decal to put on your car.
Old Sep 30, 2009 | 11:41 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Very well put and I agree!
If you get the Qjet rebuilt, be absolutly sure you get it done by somebody that KNOWS THAT CARBURETOR! And get the shaft seals done the first time, instead of having to take it back with a vacuum leak that they didn't correct the first time. Be sure they seal the plugs at the bottom of the casting.
If those things are done and the rest of the carb is remanufactured properly, it will perform well for YEARS.
One more thing: Don't just buy a reman carb. That is a carb that's off the shelf, put together with parts from a hundred others. When you get YOUR OWN carb rebuilt, you get parts that are all worn in together and the end product is a much nicer unit.
Old Sep 30, 2009 | 11:47 AM
BKbroiler's Avatar
BKbroiler
Assuming your intake manifold is made for a spread bore carb, switching to an Edelbrock will also require a new manifold or an adapter which might create hood clearance problems. You could try a spreadbore Holley which is a direct replacement for the Qjet. Your best solution is to get the Qjet properly rebuilt.
Also, Roughrider is 100% correct in all the issues he described.
Old Sep 30, 2009 | 01:02 PM
Roughrider's Avatar
Roughrider
The Performer intake will accept a spread-bore or square-bore carburetor...no problem in that respect. I do agree you should get your own Q-jet rebuilt instead of buying an off the shelf rebuilt carb. When I was in the auto repair business years ago, I don't remember ever seeing an off the shelf rebuilt carb worth a damn. The defect rate on them was horrendous. Maybe that's changed...I don't know.
What you might consider is to contact Edelbrock. They used to make new Quadrajets but discontinued them a few years back. Several months ago they had a clearance sale on their leftover inventory...maybe they have a few left at closeout prices. Ask them and see what they might have for you. The worst that can happen is they're out of stock completely and you still rebuild your original Q-jet.
Old Sep 30, 2009 | 03:39 PM
timbuck's Avatar
timbuck
I called Edelbrock and they said they no longer had any in stock. I called Summit and they said the same. Summit does offer a rebuilt Quadra-jet with a 1 year warranty for $299.00. Any of you ever buy one of these from them, and if so, what did you think? The guy from Summit was saying that the Edelbrock Quadra-jets were n excellent product and he could not understand why they stopped producing it. It was his understanding that they even destroyed the tooling when they stopped making them. Must have been so people would buy their designed carbs.
Old Sep 30, 2009 | 03:50 PM
SanDiegoPaul
Please refer to my post above, about NOT buying a reman Quadrajet. Save yourself the time, effort, and trouble.
Old Sep 30, 2009 | 04:37 PM
Roughrider's Avatar
Roughrider
DO NOT BUY A REMANUFACTURED CARBURETOR! Have yours rebuilt by someone who knows Q-jets. The only way I would buy a reman carb is to have a builder who knows and understands Q-jets and Corvettes. That person can take a Q-jet and build it to suit your needs. An assembly line rebuilt Q-jet, no matter how well it's done, will not be set up for your application and will still need to be gone over by a specialist to match it to your car.
I can only assume Edelbrock stopped production of their Q-jet due to lack of demand. While an excellent carburetor, the Q-jet has always suffered from a myth about it being trash...Quadrajunk, Rottenchester, etc. Very undeserved and I imagine that Edelbrock discovered that still to be an issue. The market speaks...you don't keep producing a product that doesn't sell...a bad way to stay in business...unless you're the government!
I doubt if Edelbrock destroyed the tooling...they didn't make them. Their carbs are made for them under license by a subcontractor.
Old Sep 30, 2009 | 04:58 PM
7T1vette's Avatar
7T1vette
If you're willing to spend $300 on a carb, why not buy a $30 book on how to rebuild Q-jets, $40 on a rebuild kit and new Nitrofil float, then do it yourself. If you take a couple hours to read over the rebuild instructions in the book, you could easily rebuild your existing carb in a day. Then, the carb is freshly rebuilt, it is all configured correctly for your car and you save over $200. Plus, you will then understand how the carb works and how to adjust it properly. Now, I call that a good investment $$$. {Not to mention that the Q-jet is, in many ways, a better carb than most Holley's and is much more economical (mpg) under normal driving conditions.}
Old Sep 30, 2009 | 05:19 PM
Iroc57's Avatar
Iroc57
Good advice here
If you build it..then you can fix it
Old Oct 2, 2009 | 07:41 PM
blu73's Avatar
blu73
If you can find Lars somewhere here on the forum, contact him. He used to rebuild Q-jets and may be able to help you with yours. It has been a while since I last contacted him, but at that time he was still doing rebuilds. I had a distributor done by him and am very pleased.
Old Oct 2, 2009 | 07:54 PM
Clams Canino's Avatar
Clams Canino
Agreed. Lars is renowned for Q-jet rebuilding.
-W
Old Oct 4, 2009 | 03:48 PM
Oldguard 7's Avatar
Oldguard 7
Lars checks in from time to time at VetMod.com. He left this forum this past February.
Old Oct 4, 2009 | 04:06 PM
Project80's Avatar
Project80
Why do you feel that your Qjet needs rebuilding? Are there problems?
Old Oct 4, 2009 | 04:15 PM
Jeff_Keryk's Avatar
Jeff_Keryk
The Edel QJets are great carbs. I have one on my 65 442. I think I read somewhere about 5 years ago there was some legal reason Edel had to stop manufacturing them. And they were kinda pricey, and of course most people think they are junk. To these people I say, "I love my Quadrajunks."
Old Feb 4, 2010 | 01:39 AM
C3Vettes.net's Avatar
C3Vettes.net
the problem with this is that it does not address bad throttle plate pushings or warped parts. to correctly rebuild (opposed to "refreshing" as described above) you are looking at $500-$600 but will have a great carb.
Old Feb 4, 2010 | 07:01 AM
Roco71's Avatar
Roco71
I am not sure of the level of rebuild you are looking for if you are looking to keep it original and in show condition like new or even better use these guys www.daytonaparts.com I had them rebuild and recondition a carburetor for me a few years ago. They re-plate parts to look new and recondition everything. Turn around time was 3 weeks. It will cost you the price of the aftermarket carburetor, but be correct for your car.
To Edelbrock performer
Old Feb 4, 2010 | 09:46 AM
81pilot's Avatar
81pilot
Nah he is here quite often, he emailed me his papers a few weeks back, however he no longer does rebuilds.
Old Feb 4, 2010 | 09:59 AM
71rdster's Avatar
71rdster
Talk to Lars and get a copy of his paper on rebuilding the Qjet. Get a quality Qjet rebuild kit, and do it yourself. Several here on the forum have rebuilt their carbs using Lars Qjet rebuild paper to guide them. All seem pleased with the results.
Old Feb 4, 2010 | 12:29 PM
thegazman's Avatar
thegazman
Default thegazman
Contact "Jet Performance". They are about the only company that has a decent rebuilt q-jet.
