4 Barrell not opening up - HELP
Old Sep 30, 2009 | 10:35 PM
foseguera's Avatar
foseguera
Default 4 Barrell not opening up - HELP
Hello All,
I have a edlebrock 800 4 barrel carb on a 350 small block 1975.
I don't know why, but I would guess 2 weeks ago, my 4 barrel stopped opening up.
The engine was rebuilt recently, the engine is working great, what could have caused this?
Any ideas??????
Best; thank you so much for your time,
Felix
Old Oct 1, 2009 | 01:43 AM
Z-man's Avatar
Z-man
What do you mean that it "stopped opening up"? Is the linkage broken?
Old Oct 1, 2009 | 03:03 AM
RunningMan373's Avatar
RunningMan373
If the choke plate doesn't fully open, because of the choke spring not fully opening, the secondaries will be locked out- exhaust gas routing problem. Other cause could be that the throttle cable was moved forward in it's holder, or not installed correctly to get a full pull on the carb.
Old Oct 1, 2009 | 04:52 AM
baxsom's Avatar
baxsom
i am guessing edelbrock spread bore? could it be because the 800 cfm carb on a 350 is so huge that the engine doesnt need that much air, vac secondaries are demand only. if the engine doesnt need it, the valves wont open.
plus, how do you know they arent opening. did you do the paperclip trick or something similiar like can be done with a holley. a properly working vacuum secondary carb should transition into the 4bbl so smoothly that you wont notice.
Old Oct 1, 2009 | 09:48 AM
7T1vette's Avatar
7T1vette
Did you install some new floormats? ...insulation under the carpeting? If the throttle cable/linkage extends the throttle to full-travel on the carb when your foot is "to the floor", then you have a mechanical problem with the linkage/actuation mechanism on the carb. If it does not open the throttle completely, adjust the throttle linkage and/or the cable adjustment on the accelerator pedal.
To 4 Barrell not opening up - HELP
