Transmission TH700R4 - help
Old Oct 1, 2009 | 04:07 AM
Zimmi's Avatar
Zimmi
6th Gear
Default Transmission TH700R4 - help
My tranny has suddenly lost reverse. I have all forward gears. Does anyone have any ideas? Is this going to be a new tranny or is is easily repairable?
Old Oct 1, 2009 | 10:00 AM
7T1vette's Avatar
7T1vette
First, you will need to determine if the shift linkage/cable is actually rotating the shift shaft properly to move the shift valve into the reverse detent. If it is properly positioning the shift shaft/valve setting, then the problem is internal. If all the other ranges work properly, reverse should work also. Each range uses two [particular] clutch packs to allow proper function. Reverse uses the same packs used in other ranges...just in a different 'combination' than with the others. So the clutches themselves should be OK if other ranges work. I suspect a shift linkage/cable problem...but it could also be some electronic gizmo (i.e., solenoid operated valve) on the valve body/channel plate of the tranny. I'm not familiar enough with the 700R4 to know for sure about the electrical items.
Old Oct 3, 2009 | 02:52 AM
Zimmi's Avatar
Zimmi
6th Gear
Default Cheers
Thanks for your help. My first thought was that this was going to cost a lot of $ to fix but with your input it does not look that way. I feel a lot happier now and will drop the tranny and get my hands dirty
Old Oct 3, 2009 | 03:06 AM
mrvette's Avatar
mrvette
You going to wish you drained the fluid anyway, so I would pop the pan and look for some link bar from the shift lever/shaft to the hydraulic valve in the valve body....see that it has full range,
Old Oct 3, 2009 | 05:40 PM
TimAT's Avatar
TimAT
Drop the pan. If the other gears work then it's not the manual part of the linkage- either inside the trans or out. the only electrics in a 700R4 are for the lockup convertor and or indications to the ECM about which gear it's in.
The low and reverse clutches are at the rear of the trans. There's a big piston that's the very first piece that goes in during a full rebuild. 3 seals on that one. IIRC, the fluid is ported to that and the input clutch for reverse. Step one needs to be drop the pan and see how much trash is in there.
Old Oct 6, 2009 | 02:00 PM
72-454's Avatar
72-454
A few years ago I had the same problem, suddenly no reverse anymore on my 82. When I removed the oil pan I found the linkage loose (inside the pan). A small metall clip was broken which was holding a pin in place. Just reconnected it and secured it with a selfmade clip. No cost except some oil and gasket.
Hope nothing severe broke on your tranny!
To Transmission TH700R4 - help
