Replace Heater Water Control Valve
Old Oct 4, 2009 | 04:16 PM
SoCalErv's Avatar
SoCalErv
Army
Default Replace Heater Water Control Valve
Well I need to replace the heater control valve in my 69 with AC.
Any easy way goining about this? The valve is located in the passenger's fender well and seems this will be a PITA.
Old Oct 4, 2009 | 04:36 PM
SIXFOOTER's Avatar
SIXFOOTER
pretty straight operation, 2 clamps and a couple screws. Course if ya have meathooks like mine your probably gonna bleed a bit.
Old Oct 4, 2009 | 05:22 PM
Duke94's Avatar
Duke94
You'll make less of a mess if you drain the Rad.
Gary
Old Oct 4, 2009 | 05:34 PM
SoCalErv's Avatar
SoCalErv
Army
Do you come in from the top or is there a secret that can make this job a helleva lot easier?
Old Oct 4, 2009 | 07:16 PM
TimAT's Avatar
TimAT
Clamp off the heater hoses with vise grips. If you're not changing the hoses, it's quicker than draining/refilling the system.
Old Oct 4, 2009 | 08:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Probably have to go at it from the top and it might make it easier to do some of it from undernieth. Clamping the hoses is a good idea.
Old Oct 4, 2009 | 08:24 PM
speedreed8's Avatar
speedreed8
i did like timat, clamped off the hoses, put the car on the ramps and tackled it from underneath.
Old Oct 4, 2009 | 11:43 PM
southern_vette's Avatar
southern_vette
you have jack it up, put it on jack stands and remove the passenger side splash shield to get to it, it is not very hard to get to from the bottom side, but if the hose are old it might be worth your time to go ahead and get new hoses and just cut the old ones off instead of trying to work them loose.
Old Oct 5, 2009 | 12:20 PM
7T1vette's Avatar
7T1vette
Since you have no side vents that are removable, your best access is from the bottom. Try using the Vise-grips to clamp-off the water hoses. If they break or crack, you'll know it's time to replace them...otherwise, just replace the valve and hook them back up.
P.S. Put a drain pan under your work area when you install the vise-grips. If the hose breaks, you'll need it.
Old Oct 5, 2009 | 12:39 PM
kaiserbud's Avatar
kaiserbud
Originally Posted by southern_vette
.....and remove the passenger side splash shield to get to it, .
To Replace Heater Water Control Valve
