Big Inch Small Blocks - HERE
Old Oct 12, 2009 | 01:09 PM
holley505's Avatar
holley505
Default Big Inch Small Blocks - HERE
hey guys... just wonder who has a Motor Larger than 350 Cubic Inches?
If so post up what size motor you have and tell us a little about the motor.
Also... if you can post a 1/4 or 1/8 ET that would be Great !!
Old Oct 12, 2009 | 02:06 PM
v2racing's Avatar
v2racing
I have a 406 small block, it's a Gen I not a Gen III like your LS3. It runs extremely hard but is still very steetable. It's pretty easy on gas (20 mpg interstate driving) as long as you stay out of the go pedal. All this is owed to putting the right combination of parts together, attention to detail, and spending the time to tune it properly. Details in my signature.
Old Oct 12, 2009 | 02:08 PM
holley505's Avatar
holley505
Originally Posted by v2racing
I have a 406 small block, it's a Gen I not a Gen III like your LS3. It runs extremely hard but is still very steetable. It's pretty easy on gas (20 mpg interstate driving) as long as you stay out of the go pedal. all this is owed to putting the right combination of parts together, attention to detail, and spending the time to tune it properly. Details in my signature.
Nice setup ... sounds pretty close to mine. But I have a GEN III motor
what gear are you running?
Any track times?
Have you had your car on the scales?
Old Oct 12, 2009 | 02:12 PM
v2racing's Avatar
v2racing
It has 3.07 gears for now. 3.73's are in it's future. No track times. I raced professionally for years and probably won't ever put this one on the track. I tend to get carried away. It is just for fun on the streets.
I haven't put it on a scale but I pulled quite a bit of weight out of it. Used aluminum where I could. 80's were lighter to start with too.
Old Oct 12, 2009 | 02:50 PM
holley505's Avatar
holley505
mine weighed 3150... with the 346.
But I have pulled out a lot of stuff with the new engine... hopefully I will get below 3,000
Old Oct 12, 2009 | 03:14 PM
groovyjay's Avatar
groovyjay
434ci here.
Old Oct 12, 2009 | 03:24 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
406 sb with a bunch of stuff added to produce 490hp with 529 ft.lb torque
Old Oct 12, 2009 | 04:59 PM
gkull's Avatar
gkull
You should add that you have a heater and A/C!
You can stuff a 4 inch stroker in a Gen III and get 408 ci. Most of the NA stroker motors are usually doing about 11.40 11.70 with solid roller cams.
Old Oct 12, 2009 | 06:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I rolled of the line 2.4 60ft shifted from 1st to 2nd missed 3rd and hit 5th coasted a bit and then finally got it into third and turned 14.1 @ 112mph that's enough for this year.
My buddy who owns an engine shop says I need a autonatic and should turn low 11's to mid 10's and he never sugar coats anything
Old Oct 12, 2009 | 06:13 PM
ARCH's Avatar
ARCH
best ET 11.85
best MPH 119.5
3130lbs with me in the car. 4-speed, 4.11 rear
Old Oct 12, 2009 | 06:45 PM
v2racing's Avatar
v2racing
Both of those come in handy up here!
Old Oct 12, 2009 | 07:40 PM
69tuxedocoupe's Avatar
69tuxedocoupe
383 Cubic Inch stroker and ported polished heads on a numbers matching engine. 400HP and 460 ft. lbs of torque.
Zora would have wanted it that way.
Old Oct 12, 2009 | 07:44 PM
C3 Stroker's Avatar
C3 Stroker
427 here.....street car, sleeper, mid 10's......see my sig. for info.
Also on page 86 of Super Chevy magazine, Nov. 2009 issue...(Red Rocket)
Old Oct 12, 2009 | 08:09 PM
Shirley1978's Avatar
Shirley1978
381 stroker.
9.6:1
hyd roller cam (286 comp)
all forged, internally balanced
afr 195s, stealth intake
quick fuel 750 carb
18mpg hwy
dynoed 453hp 460lbs tq
3.36 rear end, cooper cobra tires
soft launching, no power shifting due to iffy diffy.
13.2 1/4 mile so far.. but im sure in the 12's easy
Old Oct 12, 2009 | 09:13 PM
holley505's Avatar
holley505
groovyjay and Glass Act... no times with these motors?
Old Oct 12, 2009 | 09:15 PM
holley505's Avatar
holley505
Nice I like this... what stall converter and gear in this car?
Large cam? Or nice roller?
Old Oct 12, 2009 | 09:36 PM
Glass Act's Avatar
Glass Act
Sorry holley505 I've never sent it down the track. My engine builder said it would be into the 11's with my setup and 4.56.1 gears, but can't say thats true without a track time.
To Big Inch Small Blocks - HERE
Old Oct 12, 2009 | 11:00 PM
forvicjr's Avatar
forvicjr
Not a corvette but a previous build. 408 SB, 230 dart pro ones, dart single plane, comp 588 lift solid roller, callis crank, oliver rods, wisco pistons, all packed in a 91 S-10 with all wheel drive from a syclone donor. dynoed at 572 HP (flywheel) went 6.70s 1/8 on sreet tires(nitto 555s)18/9.5 wheels all on motor. could be good for more but sold before tuning it completely in....
Old Oct 13, 2009 | 12:37 AM
Bee Jay's Avatar
Bee Jay
You get 20mpg with a 250 degree camshaft, 3500 rpm stall converter, and 406 cubic inches? How do you do that?
Bee Jay
Old Oct 13, 2009 | 12:42 AM
Gale Banks 80''s Avatar
Gale Banks 80'
400ci, GMPP Aluminum Block, Scat Crank, Carrilo Rods, JE Pistons (had to have them custom made to fit a stock bore) ARP 180 Heads, Manley Valves, Comp Hyd Roller, Accel Gen 7 FI, Gale Banks Twin Turbo. Yet to Dyno it yet but close. Idles at 800 RPM with 16inchs of vacume, should make 700 with out intercooling.
