Points to electronic on a 72
Old Oct 12, 2009 | 07:35 PM
Mick 72's Avatar
Mick 72
Default Points to electronic on a 72
The more I post on here the more I realize I don't know jack about my car. With that said I'll ask another question. I have purchased the Breakerless Ignition from Eckler's for my car. Since I have used it there is a constant miss fire. I rebuilt the engine at the time I bought the ignition so all of it is new. When I mean miss fire it's like a constant skip all the time at idle and through rpms. You can hold the gas steady and hear it miss and as you gradually increase rpms. Everyone has suggested going to MSD which I already have the box I have just yet to install it trying to determine if it really is the distributor. Attached to the coil at the positive are the black and white wires and the wire from the distributor goes to the negative. What are the two wire hooked to the positive? I have heard talk of a resistor wire is that the white one? Could that interfere with the electronic ignition? This forum has been a great help. Thank you again.
Old Oct 13, 2009 | 07:12 AM
Mick 72's Avatar
Mick 72
Correction. The two wires going to the positive side of the ignition coil are black and orange, The orange wire is cover by a white insulator.
Old Oct 13, 2009 | 07:29 AM
bashcraft's Avatar
bashcraft
The orange wire is the resistor wire. Normally it's not used with electronic ignitions. What did the directions say that came with the ignition?
Did you verify which cylinder it is and whether or not it has spark? Are you sure you have the firing order correct?
I wouldn't be so quick to blame the ignition. There's a number of other simple things it could be.
Old Oct 14, 2009 | 04:51 PM
Mick 72's Avatar
Mick 72
The directions are pretty much general. I don't think all cars would have had that resistor wire but I don't know. I checked all the plugs they all look the same. I have not removed each wire one by one while running but that may be an idea. I did however find that the coil I'm using has too low of an ohm rating. I am using the accel super stock 45,000 for electronic ignitions that has a primary ohm rating of 0.7 but the Breakerless website said not to run a coil with less than a 1.2 primary rate.
Old Oct 14, 2009 | 07:40 PM
7T1vette's Avatar
7T1vette
Did the installation instructions tell you to use the existing wiring to feed power to the electronic module? Or did it tell you which terminal on that module was to get +12 vdc? If it is to get a full 12 vdc, you will have to bypass that resistor wire and run another wire from an IGN connector at the fuse block (+12 vdc when the ignition is turned "ON").
Old Oct 16, 2009 | 12:48 AM
smokinvette73's Avatar
smokinvette73
I'd say that your timing is out. You took the distributor out and the new one is out by a notch or two.
Old Oct 16, 2009 | 09:04 AM
71coupe454's Avatar
71coupe454
Yes Im with the other guy, first make sure you dont have a issue with the O.E. wire not being a full 12v. I think its only 4-5v for the orig points system.
Old Oct 18, 2009 | 03:33 PM
Mick 72's Avatar
Mick 72
After all the help I researched more and I found detailed instructions on the internet. I found that my coil had too low of an ohm resistance. Still fooling with the timing but haven't quite got there yet. Thanks guys.
Old Oct 18, 2009 | 05:32 PM
Ganey's Avatar
Ganey
Originally Posted by Mick 72
... I have purchased the Breakerless Ignition from Eckler's for my car. Since I have used it there is a constant miss fire. I rebuilt the engine at the time I bought the ignition so all of it is new. When I mean miss fire it's like a constant skip all the time at idle and through rpms. You can hold the gas steady and hear it miss and as you gradually increase rpms. ...
If you used your old spark plug wires, you may need new ones esp. if a higher energy system. Check wires on cyl. 5 & 7 first & that they are in the right order.
Old Oct 18, 2009 | 10:54 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by Ganey
If you used your old spark plug wires, you may need new ones w/ a higher energy system. Check wires on cyl. 5 & 7 first & that they are in the right order.
The breakerless conversion systems do not increase the output of the coil.
Was the distributor re-shimmed properly?
Old Oct 18, 2009 | 11:03 PM
sonny_burnett's Avatar
sonny_burnett
I think the reason they say 1.2 ohm coil is they assume you aren't using a resistance wire or ballast. But, I think you are using the resistance wire, so I don't know why a 1.2 ohm coil would help.
Old Oct 19, 2009 | 07:31 AM
Ganey's Avatar
Ganey
1) It was not stated it was a conversion.
2)
is not the stock coil.
3) I offered 3 possible solutions.
a) plug wires may not have been put back in correct order.
b) check 5 & 7 in particular.
c) spark plug wires may need replacing esp. if a higher energy system.
And you have a complaint.
I could have phrased it better.
Old Oct 19, 2009 | 08:39 AM
7T1vette's Avatar
7T1vette
M.Ward was indicating that if the coil and the stock supply feed wiring were not changed, the plug voltage would not be any higher than with the points in the system. To get full advantage of the electronic system, the coil needs to be changed and a direct 12 vdc line needs to feed it; then the plug wires [probably] need to change also, unless they are designed to handle the higher voltage produced. The coil, the coil supply voltage, and the gap on the spark plug determines the spark voltage that is produced.
Old Oct 19, 2009 | 09:16 AM
Ganey's Avatar
Ganey
1 It was already made clear that a different coil was being used.
2 As you pointed out earlier, that had not been determined.
Old Oct 19, 2009 | 09:51 AM
Mike Ward's Avatar
Mike Ward
2)
1)my
2)statement
3)is
4)still
5)correct
6) Relax, enjoy.
To Points to electronic on a 72
