Hood insulators??
Old Oct 12, 2009 | 07:47 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Default Hood insulators??
I'm needing to replace the insulator in my '75.
Wanted to know if anyone has done any custom insulators or ditched the insulator and painted?
Show me what you've got.
Old Oct 12, 2009 | 09:11 PM
thegazman's Avatar
thegazman
Default thegazman
About the only thing the hood insulators does is absort the sound from the engine. From experience....it won't hurt the hood without it, but you will get a lot more engine noise inside the car. The windsield glass does not insulate the noise from the engine very well.
Old Oct 13, 2009 | 09:06 PM
stingraymyway
Thanks for the info.
The old one is getting grungy.
Planning to get a new one this weekend at the Corvette Expo.
Just wanted to know if anyone had done any custom work.
I know they're out there.
Old Oct 13, 2009 | 11:46 PM
blackbeauty74's Avatar
blackbeauty74
I am also in need of some hood insulation. If I really dont need it then I wont worry about it, but doesnt it protect the paint on your hood from the heat of the engine?
Old Oct 14, 2009 | 12:09 AM
SH-60B's Avatar
SH-60B
The paint on my hood is undamaged after years without an insulator.
Old Oct 14, 2009 | 12:21 AM
Mike Ward's Avatar
Mike Ward
Noise only.
Old Oct 14, 2009 | 02:25 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Took mine off and had the underside painted,
Old Oct 14, 2009 | 05:36 AM
73StreetRace's Avatar
73StreetRace
Nice flames ! I like it !
I used Cool It Thermo-tec insulating materials ( 1/4" thick ) :
Old Oct 14, 2009 | 11:35 AM
1ARACE's Avatar
1ARACE
The insulator also helps protect your paint. If oil or other contaminants sling up on the underside of your hood and get into the fiberglass it can cause the paint on top of the hood to bubble; if it does prepare for a hard battle to decontaminate the fiberglass and get it painted without the bubbling coming back. Ie. taking it down to the fiberglass then baking and cleaning over and over for days, possibly even weeks depending how contaminated it is, and you could end up having to buy a new hood worse case scenario.
Old Oct 14, 2009 | 05:17 PM
stingraymyway
Nice work folks.
Keep 'em coming.
Old Oct 14, 2009 | 06:29 PM
terry82's Avatar
terry82
look at one of our supporting venders, under the hood insulaters by paula
Old Oct 14, 2009 | 07:40 PM
SH-60B's Avatar
SH-60B
This is very unlikely.
Old Oct 14, 2009 | 09:45 PM
1ARACE's Avatar
1ARACE
If you think that then go ahead and try it.
Unlikely? Well i've been through it and it sucks, and here's some other's who have as well...so how so unlikely is it now?
http://forums.corvetteforum.com/pain...ibreglass.html
http://forums.corvetteforum.com/pain...ated-area.html
And if you want more examples, dig through the paint and body section further.
Old Oct 14, 2009 | 10:42 PM
SH-60B's Avatar
SH-60B
Roger Wilco. I have a couple of junk t-tops. What brand of oil do you recomend?
BTW - Why don't you show me an example of oil on the bottom of a hood screwing up the paint on the top of the hood? Hmmm?
Old Oct 14, 2009 | 11:28 PM
1ARACE's Avatar
1ARACE
Instead of being a smart ***, why not read the links I posted...since apparently that would take too long for you to do...here's a quote from one....
Originally Posted by grandmastercorvette
When your hardtop is outside...flip it upside down...and the ATF will come to the top surface ...where it can be wiped off with chemicals. This allows gravity to help in this issue...causing the fluid to go down...which will make it appear on the top surface of the hardtop.
I just had to do a hood on a 1970 with a major oil spot in it...due to an oil breather puking oil on the underside for along time and the owner not keeping up with "things". I turned the hood upside down...and applied a heat lamp on the engine side of the hood... and got the oil to flow to the top surface..(which was facing towards the ground) and wiped it off...and did this for about a week and got the oil stain to go away. If you can remove the headliner...this may help in allowing the sun to get to the fiberglass and really heat things up.
Maybe this will help you also...if other ideas do not fix it.
"DUB"
Old Oct 15, 2009 | 03:54 PM
SH-60B's Avatar
SH-60B
Mkay. Neither one involves the underside of a hood. Instead of being an ***, why don't you show me an example of oil ruining a hood?
Old Oct 15, 2009 | 04:02 PM
SH-60B's Avatar
SH-60B
Apparently, some model years simply did not have a hood insulator at all. Do you think all those hoods were endangered by a possible oil leak? I didn't think so either. If any thing, the hood insulator would act like a sponge and hold oil against the underside of the hood, all the more reason to get rid of it. Well, at least we got that settled! Look in here: http://forums.corvetteforum.com/c3-t...nsulation.html
To Hood insulators??
Old Oct 15, 2009 | 04:03 PM
SH-60B's Avatar
SH-60B
Ditched it, sorry no pics.
Old Oct 15, 2009 | 05:09 PM
1ARACE's Avatar
1ARACE
You are completely correct, it doesn't happen...
http://forums.corvetteforum.com/pain...-one-spot.html
http://forums.corvetteforum.com/pain...t-is-this.html
http://forums.corvetteforum.com/pain...g-on-hood.html
http://forums.corvetteforum.com/pain...l-on-hood.html
Yep settled, you win, because there is no way on earth fiberglass is susceptible to oil, brake fluid, silicone, or other contaminants.
Old Oct 16, 2009 | 08:19 PM
stingraymyway
Getting my replacement hood insulator tomorrow at the Corvette Expo!!
