Motor Oil tests
Old Oct 28, 2009 | 12:26 PM
  #81
glen242's Avatar
glen242
I use Valvoline VR-1 10W-30. ZDDP is 0.14/0.13 and has an additive package that allows for street use.
Check their web site for all the specs.
Old Oct 30, 2009 | 03:23 PM
  #82
cottoneg's Avatar
cottoneg
From The website mentioned above:
“To achieve these goals, automotive manufacturers have pressured their oil suppliers to remove substances from motor oils that would shorten the service life, including the proven EP (extreme pressure) additive ZDDP (zinc dialkyldithiophosphate). Zinc and phosphorus from the ZDDP can be present in small amounts in the exhaust gas of an engine depending on the amount of oil which is consumed in combustion. These elements can coat the catalyst reducing the amount of catalyst exposed to the exhaust gases, ultimately increasing emissions at the tailpipe. As a result of the EPA mandate, the ZDDP level in engine oils has been declining since the mid-1990s, roughly coinciding with the implementation of OBDII.”
I am assuming that while fine for our cars, this would kill the catalytic converts in the newer cars.
