Body Mount Repacement Experts Chime In
Old Oct 18, 2009 | 02:52 PM
Kim72's Avatar
Kim72
Default Body Mount Repacement Experts Chime In
I'm in the middle of replacing the body mounts on my ride. Everything is pretty much ready to go and the old bolts are out or loose. Old bolts came out reasonably well!! My concern is the lifting of the front end without cracking the fiberglas any more than it is (small cracks around the headlights). I'm having trouble visualizing the front end lifting while I'm jacking up the sides (one side at a time). There's a lot of weight out there!!! Should the hood be off?? Is this a lift I can do on my own or should I get help?? Any advise will be appreciated.
Old Oct 18, 2009 | 02:59 PM
LannyL81's Avatar
LannyL81
When I did mine, I used a 2x6 jig that went under the door area; used my floor jack. All I had to do was to raise is 1/8" to get the old rubber mount out and the new poly mounts in.
I think I screwed two 2x6's together with a gap between them that the lip of the body fit into. Mine were about 30" long. Someone here probably has this and can show it to you.
Good luck
Old Oct 18, 2009 | 03:24 PM
Kim72's Avatar
Kim72
Good luck
I plan to do just that, but did you unhook/remove front end bolts to raise the body?? Did you have a concern with the front end fiberglas?? All I've read says that one must raise body approx. 4" to get at the mounts.
Old Oct 18, 2009 | 05:52 PM
Alan 71's Avatar
Alan 71
Hi K72,
Quite a few parts (bumpers for example) are bolted THROUGH the body to the frame both front and rear. What all have you unbolted to let the body rise up? I can't really tell from your post. This IS something you can safely do, as Lanny said ,as long as everything's loose.
Regards,
Alan
Old Oct 18, 2009 | 08:21 PM
Kim72's Avatar
Kim72
Originally Posted by Alan 71
Hi K72,
Regards,
Alan
Almost got everything unhooked (steering column, master cylinder, clutch linkage, rocker panels, antenna, ground straps, etc...). Tranny/driveshaft are totally out of the car awaiting new T-45rs for install. Just finished unhooking all rear bumper/brace area bolts. Have been doing a little every day. Only have the front end bumper/radiator area to unhook and then I should be ready to lift. Body bolts are out on one side, loose on the other. I'm having trouble visualizing the front end lfting when I jack up the sides. Seems like a hell of a lot of weight hanging out there!!
Old Oct 18, 2009 | 10:33 PM
zwede's Avatar
zwede
Yes, you need to lift the front along with the rest. When I did my '71 I used 3 jacks. Two on the sides, one lifting the rad core support in the middle. Go slow, constantly look to make sure it doesn't snag on anything. One thing I forgot on mine was the mufflers. They jam on the inside of the quarter panels, so remove them. Some other commonly forgotten items:
Seatbelt reinforcement strap in the drive shaft tunnel.
Parking brake cable.
Old Oct 18, 2009 | 11:11 PM
Kim72's Avatar
Kim72
Thanks Zwede. Whole exhaust system is already out (except headers). Parking brake cable is unhooked. Didn't think about the seatbelt retainer strap. I will look to unhook it.
Old Oct 18, 2009 | 11:45 PM
Gale Banks 80''s Avatar
Gale Banks 80'
The late C's are a little diffrent in the front end so I'm not sure there but I didn't unbolt much up front. Keep in mind that You can do one side at a time you don't need to lift it all at once. 4" of Lift would be great but You don't need to go that far. Keep in mind that the only way to replace the gas Line from the tank is to do this Job all over. Yes do it all over again.
Old Oct 19, 2009 | 05:50 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I know early C3's like my 71 have solid body mounts. What are you replacing them with?
Old Oct 19, 2009 | 07:12 PM
Kim72's Avatar
Kim72
I'm using the poly kit. I've replace pretty much everything else on this car with poly so far.
Old Oct 19, 2009 | 07:25 PM
redwingvette's Avatar
redwingvette
My site has a list of the things I had to disconnect. I did have to lift the body completely off though. My rocker channels were in real bad shape.
Body-off project
Old Oct 20, 2009 | 08:24 AM
Sigforty's Avatar
Sigforty
Nice, which one did you get? I only thought they made one for the 73 and later cars. When I get my body off done, I want to put in poly mounts.
Old Oct 20, 2009 | 12:59 PM
Kim72's Avatar
Kim72
I'm using the Energy Suspension kit (No. 3.4126) for my 72. Kit comes with everything except the bolts. For the bolts I have grade 8 which I picked up locally. Bushings can be had in red or black color. You can get the kit at most parts suppliers. Your right, kit is suppost to be for 73 cars and newer but you can use it for earlier Sharks.
Old Oct 20, 2009 | 03:27 PM
Sigforty's Avatar
Sigforty
Nice to know thanks!
Old Oct 20, 2009 | 09:32 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try this link.
I used the method in this link: http://www.europeancorvette.com/html...eplacement.htm
It helped me big time and i was able to just remove the bolts from the front side brackets to frame without removing the front bumber. Just one side at a time and left the other side loose. Also need to remove the radiator core support bolts in the fender well also. Just look it over a few times and yes i did try to support the radiator but it seemed to do ok by itself.
Hope this helps,
cardo0
Old Oct 23, 2009 | 06:39 PM
Kim72's Avatar
Kim72
Hope this helps,
cardo0
Looks like I'm ready to lift!! I've unhooked the front end. One bolt was a pain in the a$$. It looks to me that the rad and support will lift with the front end. Yes/no?? The support looks attached to the body and not directly to the frame. Can someone confirm this for me??
Old Oct 23, 2009 | 07:58 PM
zwede's Avatar
zwede
Yes, the core support has 6 bolts to the body and 2 to the lower cross member. Be sure the cross member is detached from the frame.
Old Oct 25, 2009 | 10:54 PM
Kim72's Avatar
Kim72
Yahoooo.
Body mounts are in and torqued down. Doors close as before and the door gaps are no worse or better than they were before. Body sits about 1/4" higher than it did (aluminum spacers to poly). I can live with that!! Now I can start putting it back together. While not hard, this was a time consuming little project.
Old Oct 26, 2009 | 06:00 PM
redwingvette
Congrates. Nothing like a do-it-yourself project completed.
To Body Mount Repacement Experts Chime In
