Power Window Motor Replacement
Old Oct 20, 2009 | 10:41 PM
RedZR's Avatar
RedZR
Default Power Window Motor Replacement
Hello,
On a 1978 model how does one replace the power window motor if the window is all the way in the "up" position?
I can get the door panel off and know where the motor is, but do I have to run that bolt through the regulator to secure if before removing the motor? If so, any suggestions on how to lower the window to get those holes to align?
Old Oct 21, 2009 | 12:04 AM
RIO68's Avatar
RIO68
Shouldn't--take the 3 bolts out of the motor and the bottom bolt out of the regulator so it can swing out just a little at the bottom where the motor is. That lets the motor clear and come out. You bolt the regulator when you have it out and the motor is still bolted to it. Once you bolt it then you take the motor off. When it is in the car and bolted to the glass it is safe to take the motor off--did that yesterday to mine.
Old Oct 21, 2009 | 01:18 AM
76 VETTE's Avatar
76 VETTE
I just replaced one of mine.If you haven't got the motor yet,Advance Auto has them for about half the cost as the corvette catalogs.
Old Oct 21, 2009 | 07:04 AM
RedZR's Avatar
RedZR
Default Power Window Motor Replacement Reply to Thread
Thanks for the responses thus far!
I did see them at Advance and will probably snag one there.
Just to make sure I totally understand- I do not want to screw this up-if the window is up all the way you do not have to insert the bolt into the regulator to hold it. Also, does the window need to be secured while it is up (will the window move or fall once the motor is removed)?
Thank you again!
Dan
To Power Window Motor Replacement
